"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=2e4,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div","\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0432\u0430\u043c, \u0447\u0442\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043f\u043b\u0430\u0433\u0438\u043d AdBlock \u0432 \u0432\u0430\u0448\u0435\u043c \u0431\u0440\u0430\u0443\u0437\u0435\u0440\u0435, \u0438\u043b\u0438 \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u043d\u0430\u0448 \u0441\u0430\u0439\u0442 \u0432 \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0439 (\u0431\u0435\u043b\u044b\u0439 \u0441\u043f\u0438\u0441\u043e\u043a). \u0412 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435 \u043f\u0440\u043e\u0441\u043c\u043e\u0442\u0440 \u0441\u0430\u0439\u0442\u0430 \u043f\u0440\u043e\u0441\u0442\u043e \u043d\u0435\u0432\u043e\u0437\u043c\u043e\u0436\u0435\u043d. \u0421\u043f\u0430\u0441\u0438\u0431\u043e."],["span",{id:i},"Ok, \u042f \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u043b \u0431\u043b\u043e\u043a\u0438\u0440\u043e\u0432\u043a\u0443!"]],"");n=1e3>n?200:n,"undefined"!=typeof window.localStorage&&null===window.localStorage.getItem("regainShow")&&window.localStorage.setItem("regainShow",0),setTimeout(function(){var e=document.body;e.innerHTML="",e.appendChild(p),p=document.getElementById(a);var n=Math.max(window.innerHeight,document.documentElement.clientHeight,document.body.clientHeight)/2,o=n-p.offsetHeight/2-100;document.getElementById(i).onclick=function(){window.location.reload(!0)},t(r,"body","background:#eee",4),t(r,"body > div","width:100%;max-width:650px;margin:"+(o>0?o:50)+"px auto 0;",5)},n)}catch(u){throw u}}}).call(this,"95fb86ebf0e68bd6f9bf3a499ac96ff8-798-1598425629");
09.10.2020 12:22 | Никки Бриленко 0.1
В Европейском Союзе вводятся новые правила по освещениюС сентября 2021 г. в Европейском союзе будет действовать ряд новых правил в секторе освещения: Регламент единого освещения (SLR) и Регламент энергетической маркировки (ELR). И то, и другое будет иметь серьезные последствия для индустрии освещения.
Что такое SLR?
Новые правила предъявляют требования к производителям и поставщикам, продукция которых реализуется в Европейском Союзе. Регламент единого освещения (Регламент экодизайна, SLR) устанавливает общеевропейские правила улучшения характеристик продукции. SLR применяется к источникам света и пускорегулирующей аппаратуре, при этом к светильникам обращается только косвенно. Тем не менее, производители светильников должны пересмотреть правила и убедиться, что их продукция соответствует новым требованиям.
Источники света по SLR – это лампы, модули и некоторые содержащие продукты. Примером последних являются:
  • светильники, которые можно разобрать с целью проверки содержащихся в них ламп;
  • бытовая техника;
  • мебель (полки, зеркала, витрины) с источниками света.
Регламент устанавливает минимальные обязательные требования к энергоэффективности и любой продукт, не отвечающий этим требованиям, будет снят с производства. По этой причине в ЕС началось поэтапное снятие с производства люминесцентных ламп CFL (с 2021 года) и T8 (с 2023 года). Лампочки заменят новыми и более энергоэффективными. Производители должны гарантировать, что источники света и отдельные механизмы управления могут быть легко заменены с помощью общедоступных инструментов и без повреждения изделия. Они обязаны предоставить инструкции о том, как «извлечь» источник света (с помощью рисунков, текста, изображений).
Что такое ELR?
Регламент энергетической маркировки (ELR) перечисляет требования к маркировке товара и применяется только к источникам света. От производителей требуется предоставить дополнительную информацию об энергетических характеристиках, функциональных параметрах, классе модели.
Цель ELR – предоставить пользователям информацию, необходимую для выбора энергоэффективных изделий. Для этого размещается этикетка энергоэффективности на таре всех независимо упакованных изделий. По запросу покупателя поставщик должен предоставить печатную версию информационного листа о продукте (информация всегда должна присутствовать в электронном виде).
Розничные торговцы обязаны соблюдать свой собственный набор требований. Например:
  • этикетка энергоэффективности должна размещаться на видном месте упаковки;
  • в случае продажи на расстоянии также предоставляются этикетка и информационный лист;
  • рекламные объявления должны включать не только класс энергоэффективности изделия, но также и диапазон классов энергоэффективности, указанных на этикетке.
Украинский производитель осветительной техники Brille выполняет эти требования, что упрощает сотрудничество компании с европейскими партнерами и дает полную информацию о товаре украинским покупателям.
Регламент ELR включает определенные обязательства для интернет-магазинов: они должны включать этикетку энергоэффективности и информационный лист товара на веб-сайт, где он продается.
Все этикетки, созданные во время действия старых правил, должны быть заменены новыми этикетками до 1 марта 2023 года.
Новая маркировка
С появлением светодиодов за последние два десятилетия индустрия освещения перешла на светильники со встроенными светодиодными модулями и электроникой, которые невозможно заменить в случае выхода из строя. Вместо этого необходимо приобрести новый товар.
Согласно SLR, если источник света и устройство управления содержащего продукта не можно удалить для проверки, то такой продукт считается источником света и подлежит маркировке.
Регламент обязывает предоставить информацию о возможности или невозможности замены источников света и механизмов управления конечными пользователями или квалифицированными специалистами. Информация об этом указывается как на упаковке, так и в инструкциях для пользователя, обычно в виде пиктограммы.
Компания LightingEurope, представляющая производителей освещения в ЕС, представила новые пиктограммы, которые начнут появляться на светильниках, показывая, какие модели могут обслуживаться пользователем, а какие требуют услуг технического специалиста.
что такое SLR и ELR, новые правила освещения ес, какие правила освещения в европейском союзе
Новые пиктограммы, которые появятся на светильниках
Зачем это всё нужно?
Регламенты SLR и ELR – часть широкой тенденции движения членов ЕС к принципам замкнутой экономики, в результате чего будет резко увеличиваться повторное использование и переработка продуктов. Эти правила – часть обязательств правительств в экологическом плане улучшения окружающей среды. Промышленная стратегия направлена ​​на удвоение производительности ресурсов и устранение к 2050 году отходов, которых можно избежать.
После принятия ряда законопроектов европейские правительства получат полномочия по реализации политики замкнутой экономики, расширив ответственность производителей осветительной техники. Например, производители экологически более эффективных продуктов будут получать низкие счета за WEEE (ежегодная плата за сбор и утилизацию отходов). Также от производителей потребуют полностью профинансировать чистые затраты на переработку упаковки, что может привести к увеличению расходов в 10 раз.
Удивительные товары с Aliexpress
Copyright © Electric House. 2005 - 2020. Москва. Россия. При использовании материалов обязательна ссылка на: Тех.поддержка | Реклама на сайте
