"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Как обойти электросчётчик на столбе?
  • Всё для электрика
maestro
Сообщение maestro » 17 ноя, 2017 15:13
В нашем садовом товариществе вынесли все электросчётчики на улицу и установили на столбе. А у меня отопление электрическое, установлены электрические обогреватели. Стало очень дорого и накладно. Накручивает счётчик за месяц очень много. Зимой будет ещё больше.
Подскажите! Как обойти счётчик на столбе и сделать левый ввод скрытно?
Спасибо.
Сообщение Похожие темы » 17 ноя, 2017 15:13
Электросчетчик на столбе с саду
Установка счетчика на столбе
Узел учета электроэнергии на столбе
CО-505 электросчетчик
Электросчетчик в офисе
Re: Как обойти электросчётчик на столбе?
Сообщение elhouse » 17 ноя, 2017 15:32
Скрытно никак! vw_rtfm
Ставьте печку или закрытый камин. И будет вам счастье. good))
А обогреватели будут как резерв.
Алиэкспресс по Русски
Сообщение sergey_sav » 17 ноя, 2017 21:51
maestro писал(а):
Источник цитаты Как обойти счётчик на столбе и сделать левый ввод скрытно?
На нормальных профессиональных форумах вопросы воровства в той или иной форме не рассматриваются.
Сообщение Калямба » 18 ноя, 2017 11:52
maestro писал(а):
Источник цитаты Стало очень дорого и накладно
Узнайте, действует ли в Вашем регионе (населенном пункте) льготный тариф на электроэнергию при электроотоплении.
Slavik85G
Сообщение Slavik85G » 10 дек, 2017 17:44
Обойти легко, но видно будет сразу, да и издалека. В детстве помниться так станки в деревне многие подключали чтобы счетчик не крутил)
AlexShteyn
Сообщение AlexShteyn » 22 дек, 2017 21:29
Оказывается, предудущее сообщение несправедливо.
Парадоксально, но именно из-за того, что счётчик находится на столбе, задачка несколько упрощается. Правда необходимо знать тип прибора.
Интересно, что без оборудования выловить "доработку" не представляется возможным, а при его наличии закос перекладывается на банальную неполадку ....
stop))
 Новое »
