"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
КЗ в кабеле антенны
  • Всё для электрика
niti
КЗ в кабеле антенны
Сообщение niti » 16 авг, 2019 8:50
Здравствуйте!
До сих пор пользуюсь на кухне комнатной антенной после необычного КЗ. Боюсь подключать телевизор на кухне к модему, к которому уже подключен комнатный телевизор.
Дело вот в чем.
В комнате как обычно телевизор работал от родной квартирной розетки, а на кухне от розетки, запитанной мною когда-то от электроплиты.
Антенна шла из коридора дома на комнатный телевизор, потом через краб на кухню.
Всё работало годами.
Вот пришел горе-мастер с Яндекса по замене блинов плиты и начал кричать, что нужно изменить подключение коричневого провода от плиты к розетке на кухне и т.д.
После его переподключения произошло то, о чем я никогда не забуду. Антенный провод вспыхнул и превратился в уголь, рассыпавшийся на сотни частей. Вспыхнул открытый огонь в нише, где проходил кабель (хорошо не на антресоли высоко, где тоже проходил антенный кабель). Весь антенный кабель обгорел в коридоре и от коридора до комнатного телевизора. Чудом не сгорела квартира. Горе-мастер побежал в коридор и вырубил общий рубильник. Кстати оба телевизора не сгорели и работают до сих пор.
Что произошло?
Почему КЗ пошло по антенне и не сработал ни один автомат?
Теперь боюсь подсоединять телевизор на кухне к общему модему. Жэковский электрик поменял подключение электроплиты (по другой причине) и снова завел от нее напряжение на кухонную розетку. Можно ли проверить правильно ли он всё сделал и как? Не повторится всё, когда я буду подключать кухонную антенну к общему модему в прихожей? Всё равно боюсь трогать кухонный телевизор, а на нем всего два-три канала на комнатную антенну сейчас ловится (.
Спасибо знатокам!
КЗ в кабеле антенны
Сообщение Похожие темы » 16 авг, 2019 8:50
Провод РЕ в пятежильном кабеле
Напряжение на антенном кабеле
Re: КЗ в кабеле антенны
Сообщение elhouse » 16 авг, 2019 10:10
А протянуть новый антенный кабель не хотите?
Ждёте трагедии...
niti писал(а):
Источник цитаты Теперь боюсь подсоединять телевизор на кухне к общему модему
Что за модем и для чего он подключается к телевизору?
Сообщение slavapril » 16 авг, 2019 15:44
niti писал(а):
Источник цитаты Почему КЗ пошло по антенне и не сработал ни один автомат?
К сожалению, не понятно всё-таки как было подключение ранее и что там сделали ваши мастера (оба). У вас на плита 220В или 380В? И почему телевизор к модему подключаете? Может к цифровой приставке или роутеру?
 Интересное »
Вернуться в «Слаботочка»
Сейчас этот форум просматривают: Alexa [Bot] и 1 гость
