"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Перегрев спутникового ресивера INTEK S10VAOP - установка дополнительного кулера
Сообщение elhouse » 19 июн, 2019 11:22
Спутниковый ресивер INTEK S10VAOP от НТВ+ постоянно перегревается, потому, что после выключения (перевода в дежурный режим) - блок питания и тюнер всё равно остаются включёнными и работают на полную.
Процессор тюнера и трансформатор с выходным транзистором в блоке питания, как кипяток - рука не терпит. Верхняя крышка сильно нагревается.
Теперь понятно почему так быстро высыхают электролиты в блоке питания и ресивер перестаёт работать.
Проблему решил маленький вентилятор (кулер) 60х60 мм установленный в верхнюю крышку, прямо над блоком питания. Можно приклеить на любой клей или силиконовый герметик. У меня клей "Момент".
Теперь верхняя крышка ресивера холодная, хотя температура в комнате +27 гр. стоит жара, до +30 на улице.
Дополнительно увеличил площадь радиатора процессора тюнера - приклеил два алюминиевых бруска (что нашёл в своём хламе, то и приколхозил). Перегрева ресивера больше нет.
Подключение питания вентилятора с нижней стороны платы блока питания (припаяно к разъёму напрямую).
+12 обозначил стрелочкой (крайний провод). Общий провод (чёрный) или корпус прибора.
Стрелочками указал детали с перегревом - трансформатор, транзистор, процессор.
Вилку спутникового ресивера подключил к розетке A/V ресивера домашнего кинотеатра (работают от сетевой кнопки). Теперь при выключении домашнего кинотеатра - выключается и спутниковый ресивер.
Сообщение Похожие темы » 19 июн, 2019 11:22
Не включается спутниковый ресивер INTEK S10VAOP
Как подключить корпусные компьютерные кулера в розетку?
Подключение ТВ спутн.ресивера, колонок, с одного пульта
Перегрев двигателя на станке!!!
Перегрев асинхронного электродвигателя
Re: Перегрев спутникового ресивера INTEK S10VAOP - установка дополнительного кулера
Сообщение elhouse » 20 июн, 2019 1:20
Раньше верхняя крышка была горячая, как кипяток. Ну думал, что после установки кулера станет тёплая, но крышка холодная - работал ресивер вчера весь день на жаре.
Прям чудеса... :lol:
Сообщение миш » 23 июн, 2019 14:35
Николай я почитал как ты сделал. Но я пока решил в корпусе просверлить отверстия. В итоге теплоотдача на корпус стала меньше. Он хоть и теплый, корпус, но не горячий. Меня пока устраивает.
Спасибо за идею, если что воспользуюсь.
Сообщение slavapril » 23 июн, 2019 14:55
миш писал(а):
Источник цитаты решил в корпусе просверлить отверстия
Я так думаю, что пыль там насобирается...не дай бог еще и воспылает
Сообщение миш » 23 июн, 2019 15:55
Слава хорош пугать :))biggrin . Да не дай бог.
Сообщение slavapril » 23 июн, 2019 19:12
Я не пугаю. Я комп периодически продуваю - пыль собирается через вентиляционные отверстия, хотя они сбоку, а не сверху.
Сообщение миш » 23 июн, 2019 19:29
Слава я прекрасно понимаю, что пыль штука хитрая. Если посмотришь на фото , которые Николай выложил, там где кулер он поставил, у него заводские отверстия. У меня их в этом месте вообще не было. Под отверстиями наклеина сетка для улавливания пыли. И самое основное, пыль , без вентилятора, осядет на поверхность ресивера . Вот вовнутрь проникнуть чють медленнее. Я тоже чистил ПК, когда он у меня был, а вот телек за 30 лет ни разу. Открыл его, телек, в прошлом году и пыль есть, но не критично.
 Удивительное »
Вернуться в «Слаботочка»
