"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Бесплатное эфирное цифровое телевидение - Триколор в топку!
Re: Бесплатное эфирное цифровое телевидение - Триколор в топку!
Сообщение elhouse » 23 июн, 2019 12:38
ВИТАЛИЙ ЙЙ писал(а):
Источник цитаты На счет того что греются ресиверы - сейчас вроде же все ресиверы с выносным блоком питания и ничего не греется!
В этой теме речь идёт не о спутниковом ресивере, а о тв эфирной цифровой приставке.
Во всех приставках блок питания стоит внутри корпуса. Отдельный блок питания используется для питания усилителя активной антенны (если есть).
Выносные блоки питания есть на некоторых спутниковых моделях ресиверов, но это не наша тема. Наша тема - приставка.
Положи руку сверху на любой спутниковый ресивер или тв приставку - только не обожгись. Всё как грелось, так и греется.
Сообщение ВИТАЛИЙ ЙЙ » 23 июн, 2019 13:34
Вот у нас 2 приставки - которые принемают 20 цифровых каналов - про эти же приставки речь идёт? и все 2 приставки питаются от выносного блока питания! вторая приставка LUMAX -
Сообщение elhouse » 23 июн, 2019 14:21
Да, действительно - посмотрел у меня тоже выносной блок питания. Даже два блока - второй для антенны.
При работе приставка греется. Собственно они все греются.
Сообщение ВИТАЛИЙ ЙЙ » 23 июн, 2019 20:22
Сейчас пощупал, не очень греется ---а вот приставка от онлайма в железном корпусе - греется сильнее! хотя там и нет ни чего такого- как то открывал её
Сообщение elhouse » 24 июн, 2019 0:26
Источник цитаты Сейчас пощупал, не очень греется
Если трогаешь пластмассу, то и не будет греться.
Сними крышку и потрогай внутри - трансформатор, выходной транзистор (на малюсеньком радиаторе) и процессор тюнера. ОСТОРОЖНО! Можно получить ожог...
Голову надо отрывать этим конструкторам за такую работу. Раньше работали конструктора-специалисты, сейчас маркетологи. Экономия кругом.
 Удивительное »
Вернуться в «Слаботочка»
