"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Управление несколькими фонарями одним проводом
  • Всё для электрика
Valentyn
Сообщение Valentyn » 03 июл, 2019 10:00
Всем доброго времени суток .
Надеюсь на вашу помощь господа , суть проблемы вот в чем .
На кухне проведён только один провод ( +,- ), через который будет подключено 4 светильника , подскажите существуют ли какие-то блоки управления или что то такое дабы можно было управлять вкл,откл отдельных светильников через выключатель
Хочется управляться включением и отключением через выключатель , а не через ду пульт
Сообщение Похожие темы » 03 июл, 2019 10:00
Самодельное зарядное устройство с одним диодом?
Схема управления одним потребителем от двух выключателей
Проблема с проводом утюга
Сделал проводку проводом ПВС (что делать?)
Обогрев мини-теплички проводом Tash
Re: Управление несколькими фонарями одним проводом
Сообщение elhouse » 03 июл, 2019 10:16
Valentyn писал(а):
Источник цитаты На кухне проведён только один провод
Должно быть два - фаза и ноль. А лучше три - фаза, ноль, земля.
Алиэкспресс по Русски
Valentyn
Сообщение Valentyn » 03 июл, 2019 10:34
Фаза и ноль есть, земли нет
Shturman
Сообщение Shturman » 03 июл, 2019 10:52
а на выключатель тоже прокинуты провода?
Сообщение elhouse » 03 июл, 2019 12:08
Valentyn писал(а):
Источник цитаты Фаза и ноль есть, земли нет
Значит два провода, а не один.
Совет: Пригласите электрика.
Не лезьте если не понимаете...
Valentyn
Сообщение Valentyn » 03 июл, 2019 12:56
Спасибо за ваш ценный совет ,
К выключателю подведён тот же провод , в даный момент выключатель включает только один фонарь в будущем будет 4 , есть ли идеи как можной будет ими управлять отдельно каждым или хотя бы двумя группами
Сообщение elhouse » 03 июл, 2019 13:12
Нарисуйте схему. Без схемы разговора не получится.
Valentyn писал(а):
Источник цитаты К выключателю подведён тот же провод
Что за провод? Так и будем тянуть кота за хвост?
Вы не можете объяснить - мы не можем понять.
Выключатель должен быть подключён от распаечной коробки.
Valentyn
Сообщение Valentyn » 03 июл, 2019 15:40
вот схема , выключатель стоит снаружи комнаты , от которого отходит провод фаза и ноль внутрб к потолку где расположен светильник , хочу с него сделать 4, но управлять ими отдельно с помощью выключателя снаружи, провести еще провода по стенам возможности нет , только внутри по потолку
Сообщение elhouse » 03 июл, 2019 16:36
Ваша схема не рабочая. Куда подводится линия 220 вольт не показано.
Смотрите внимательно - если на вашей схеме замкнуть цепь выключателя, то получится короткое замыкание, замкнется фаза с нулём. !!!
Выключатель подключается не между фазой и нулём, а в разрыв фазы!
Правильно вот так:
На этой основе можно сделать любое количество светильников и выключателей.
Например так:
Пригласите электрика - хватит гнать пургу. Вам жить надоело? Мы запрещаем вам лезть в схему электричества!
Правилами нашего форума (пункт 3.26) запрещается давать советы по подключению электрики не сведущим людям.
У вас нет опыта, нет знаний, нет допуска и т.д. ОПАСНО ДЛЯ ЖИЗНИ!
 Новое »
