"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Схема подключения водяного насоса при использовании двумя потребителями.
  • Всё для электрика
ukrherro
Сообщение ukrherro » 13 янв, 2020 14:08
Здравствуйте дорогие друзья! privet))
Прошу помочь в решении задачи по подключению водяного погружного насоса двумя потребителями.
Суть вопроса такова.
У меня есть гараж, и там имеется водяная колонка.
А также есть сосед, которые просит подключить его к данной колонке.
Как можно организовать его подключение, чтобы он мог пользоваться используя свою фазу и ноль? При этом, чтобы моя система не запитывалась от его фазы во время использования насоса соседом???
Может есть какое-то реле? Или контроллер??
Просьба подсказать схему или готовое оборудование.
Спасибо заранее!!
Сообщение Похожие темы » 13 янв, 2020 14:08
Заземление водяного насоса
Почему ПЗР срабатывает от тримера или водяного насоса?
Схема подключения DEVIreg 316
Схема подключения бассейна
Re: Схема подключения водяного насоса при использовании двумя потребителями.
Сообщение slavapril » 13 янв, 2020 14:54
Всё можно. Только схема управления будет взаимозависимая, т.е. пока один пользуется, второй от себя управлять не сможет (это в самом простом варианте). Сейчас как всё это управляется? Какие параметры насоса?
ukrherro
Сообщение ukrherro » 13 янв, 2020 15:14
Спасибо!
Сейчас все работает только от моего считка. Насос подключаю напрямую.
Но сосед протянет свой кабель к насосу и трубу.
Насос погружной на 220 вольт. на 5 киловат кажется.
Вариант, когда один пользуется ,а второй не может - устраивает.
Как это реализовать??
Спасибо!
Сообщение slavapril » 13 янв, 2020 15:32
На модульных или обычных контакторах. При этом пока включен один контактор, он должен своим дополнительным контактом разрывать цепь питания второго, чтоб тот нельзя было включить. Ну, и наоборот, соответственно.
Gavrilo
Сообщение Gavrilo » 13 янв, 2020 17:58
А если такая ситуация вы включили насос качает а сосед берёт вашу воду открывши у себя кран или наоборот. Нужно на воду ставить электроклапан который будет открываться одновременно с подачей напряжения на насос . Схема предложенная вам slavapril рабочая но есть проблемма залипания контактов разные фазы питания ( скорее всего ) блокировка электрическая не надёжная лучше бы механическую использовать (реверсивный пускатель например) .А для открытия клапана еще отдельный контактор не связаный с насосом.
ukrherro
Сообщение ukrherro » 14 янв, 2020 5:43
slavapril спасибо за совет. Возможно, это и есть решение - установить контракторы.
Скажите, а есть ссылка на схему подключения и вообще, какой контрактор подобрать?
Спасибо!
Отправлено спустя 6 минут 47 секунд:
Gavrilo дело в том, что отбор воды будет вестись через станцию. Поэтому нет необходимости ставить блокирующий клапан. Даже если я и сосед будем одновременно использовать воду, подаваться она будет из рессивера. А вот уже в сам рессивер будет закачивать тот , кто первый включил насос (открыл воду краником у себя).
Тут вот система на контракторах от slavapril , как раз может и быть применена.
К сожалению я в этом "чайник", все делаю сам, конечно некрасиво и порой бестолково, но результаты есть. У себя в гараже проводку и щиток с стабилизатором и трансформатором я собрал сам.
Не боги горшки обжигают! )))
Спасибо!
Сообщение slavapril » 14 янв, 2020 16:11
Количество ватт (предварительно киловатты переведите в ватты) вашего насоса разделите на 220 и получите ампераж, на который надо брать пускатели. Лучше будет, если в пускателе будет не менее двух силовых контактов ( и на фазу питания и на ноль). И два дополнительных сигнальных (блокировочных)контакта - один НЗ (нормально замкнутый или закрытый) для отключения контактора соседа, когда вы качаете, второй НО (нормально открытый) для самоблокировки пусковой кнопки. Либо можно поискать контакторы, в которые уже встроены кнопки включения. В любом случае один из питающих проводов на один контактор должен идти через НЗ контакт другого, исключая одновременную их работу. Можно и тепловое реле приспособить для защиты двигателей от перегрева. Также есть готовые решения УЗД (устройства защиты двигателей). Попробуйте поваять сами. Просто ну нет пока времени рисовать.
Gavrilo
Сообщение Gavrilo » 14 янв, 2020 20:23
Спасибо!
Спасибо!
Обратите внимание на реверсивный пускатель там есть всё что нужно а самое главное механическая блокировка если один пускатель подтянут то другой не включиться никогда между ними механическая связь они применяются в грузоподъёмных механизмах (тельферы кранбалки и т.п.). Это важно блокировочный контакт тоже будет в схеме управления но механика зашита надёжная в случае залипания контакта .Удачи.
Сообщение slavapril » 14 янв, 2020 21:04
Тут может возникнуть дилемма у кого именно эту реверсивную сборку ставить да еще и чужую фазу к ней подтягивать.
ukrherro
Сообщение ukrherro » 15 янв, 2020 7:38
Ребята, спасибо большое за отзывчивость. -):
Немножко почитал про контакторы. vw_rtfm
Думаю поставить такой Контактор ИЭК КМ 20-22 AC. ( _http: //22 0 volt .com .ua /kontaktor-iek-km- 20-22-ac /_ )
Управление отдаю соседу на контакты А1 и А2, соответственно контакты фаза и ноль завожу его (они нормально разомкнуты), так как он будет реже пользоваться насосом.
Свою фазу и ноль я кидаю на насос через контакты нормально сомкнутые. !!!
Вот схема контактора.
http:// 001. com. ua/ kontaktor-modulnyy-km20-22-iek#&gid=1&pid=3
Думаю 20А достаточно, насос Водолей (Номинальная потребляемая мощность: 1,0 кВт). http: // nasos .com. ua/ pogruzhnye-nasosy/vodoley-pogrugnie/btspe-0-32-63u
Как вам такое простое и дешёвое решение??
 Новое »
