"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
2 МГЛ к одному балласту и ИЗУ
  • Всё для электрика
astra_anya
Сообщение astra_anya » 24 окт, 2019 9:46
Уважаемые электрики. Подскажите пожалуйста, можно ли подключить 2 МГЛ по 70Вт к одному балласту 150 Вт и ИЗУ (50-250). Будут ли они работать, одновременно ли поджигаться и скажется ли это на сроке службы ламп?
Сообщение Похожие темы » 24 окт, 2019 9:46
Подключение 2-х бра к одному трехжильному проводу в стене
Re: 2 МГЛ к одному балласту и ИЗУ
Сообщение slavapril » 24 окт, 2019 18:23
Ну, если лампы соединить параллельно, то возможно. Но здесь надо помнить, что в холодном состоянии в лампе пары ртути и галогениды оседают на стенках горелки, и газовый промежуток внутри нее имеет некоторое высокое сопротивление. На каждой лампе, скорее всего, какое-то свое и разное. Поэтому ИЗУ, дающее высоковольтный импульс, может сработать некорректно, ввиду того, что каждая лампа будет "диктовать" свои условия розжига. Это, так сказать, ИМХО, потому как реально не пробовал. Но теоретически по мощностям балласта и ИЗУ вроде как прокатывает.
astra_anya
Сообщение astra_anya » 25 окт, 2019 2:56
Я тоже так подумала, но на опыте получилось при включении загорается только одна лампа. Какая именно - меняется при разных включениях. Правда долго они не были под напряжением. Около пол минуты и я отключала.
И после этого я решила подключить еще одно ИЗУ для каждой лампы, но с одним балластом. Так же, параллельно. И все равно горит только одна.
Я думала там какой-то секрет, и может кто подскажет, как разобраться в этом.
Сообщение slavapril » 27 окт, 2019 17:14
astra_anya писал(а):
Источник цитаты Какая именно - меняется при разных включениях
А в чем потребность таких экспериментов?
astra_anya
Сообщение astra_anya » 30 окт, 2019 6:41
slavapril, я хочу подключить 2 лампы для подсветки растений, думала средства экономить. Но видимо, получился только эксперимент.
анатолий03
Сообщение анатолий03 » 31 окт, 2019 15:23
В светильниках (не помню как называются) лампы ЛБ или ЛД подключались последовательно.
astra_anya
Сообщение astra_anya » 04 ноя, 2019 16:14
анатолий03, мне надо металлогалогенные лампы, а не люминесцентные подключить.
 Новое »
