"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Подключение частного участка
  • Всё для электрика
vladimir123
Сообщение vladimir123 » 16 дек, 2018 21:50
Здравствуйте!
Ситуация такая. Сейчас прокладываем новую линию для подключения частного участка. На участке дом, пара бытовок и сарай. До транформатора пара сотен метров. Кабель тянем под землей. (щиток со счетчиком расположен прямо на Трансформаторе сбоку у низкой части. Мы единственные потребители. Подстанция 10/0,4 кВ).
Есть пара вопросов. Проверил ПУЭ и нормы, есть такое решение.
1. Т.к. у Трансформаторной подстанции есть "охранная зона" (10м для ТП на 10кВ), поэтому в 12 м от ТП ставим щит (2м запас). Щит подключаем от ТП через счетчик СИПом такого же сечения что кабель.
Кабель от щита уходит в землю и идет до построек.
Щит крепим над высоте 1м над землей, к двум стальным прямоугольным профилям, которые забиты на 1,5м в землю.
В щите "ноль" повторно заземляем на корпус. Крепежи -профиля используем в качестве электродов заземления.
(На трансформаторе ноль естественно глухозаземлен).
В щите ставим 3-х полюсный автомат на фазы.
2. Далее кабелем по земле запитываем ВРУ.
В качестве ВРУ также используем щит, закрепленный над уровнем земли на высоте 1м на двух прямоугольных стальных профилях, вбитых на 1,5м в землю.
Во ВРУ монтируем шину заземления. В качестве электродов заземления на первое время используем забитые профиля (в дальнейшем по весне делаем нормальное заземление треугольников или полосой).
Шину заземления перемыкаем с шиной нуля стальной полосой.
Вводной автомат (приходящий от ТП) трехполюсный.
От ВРУ запитываем сам дом и другие строения.
Вот такая схема.
И еще момент. ВРУ планируем расположить возле дома, в 0,5 м от фундамента. Посмотрел ПУЭ и другие документы. Не нашел ограничений на такое близкое расположение со строениями.
Сообщение Похожие темы » 16 дек, 2018 21:50
Освещение дачного участка.
Электрооснащение дома и участка
Схема ВРУ частного дома
Трансформатор для частного дома
Re: Подключение частного участка
Сообщение elhouse » 17 дек, 2018 0:45
Читаем внимательно информацию вверху в красном блоке!
Алиэкспресс по Русски
Perilas
Сообщение Perilas » 03 май, 2019 11:41
Здравствуйте, не могли бы рассказать как все таки вы разобрались?
 Новое »
