"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Переделка счетчика СИ-20 OWEN
fedonin
Сообщение fedonin » 07 сен, 2017 18:08
Довольно часто в промышленности применяются счетчики с предустановкой, по сути, это два параллельных счетчика, считающих одновременно, но один считает до максимально возможного числа, другой же, до заранее установленного числа, по достижении которого производится какое-то действие, при этом счет второго счетчика обнуляется, тотальный же счет продолжается. На упаковщике одной из наших печатных машин забарахлил подобный счетчик и снабжение купило OWEN СИ-20 в надежде, что он устроит. Оказалось - ничего подобного, он умеет лишь считать до заданного числа и включить по достижению его, нагрузку. Чтобы повторить цикл нужно, чтобы нагрузка сама сбросила счетчик, однако при этом общий счет обнулится что неприемлимо, да и еще потребуется реле времени, чтобы счетчик не только сбросился, но и успел произвести полезное действие. Нужно также принять меры к тому, чтобы во время срабатывания нагрузки в счете не было провалов. В общем, когда у меня в руках оказался этот счетчик я решил его переделать - переписать его программу. Теперь счетчик, точнее его выход, может работать в пяти режимах: в режиме простого срабатывания на длительность от 1 до 9 входных тактов, на время от 1 до 9 секунд, выдать серию импульсов от 2 до 9, каждый длиной в такт, выдать серию импульсов от 2 до 9, каждый длиной от 1 до 9 секунд, либо переключить выход в в противоположное состояние по достижению заданного числа. Все настройки просты и интуитивно понятны, все изменения, в том числе,текущий счет, сохраняются в энергонезависимой памяти. В архиве два варианта программы с умножением тактовой частоты процессора и без, также прилагается краткая инструкция.
С Уважением к форуму, А.Федонин.
OWEN_COUNTER.zip
(28.95 КБ) 3 скачивания
OWEN_COUNTER.zip
Сообщение Похожие темы » 07 сен, 2017 18:08
Переделка проводки в квартире
Небольшая переделка проводки в комнате панельного дома
Установка gsm-счетчика
Re: Переделка счетчика СИ-20 OWEN
Сообщение elhouse » 08 сен, 2017 6:26
Исправленный файл перезалил.
Electric House - интернет-магазин электрооборудования | Алиэкспресс по Русски
fedonin
Сообщение fedonin » 08 сен, 2017 7:41
Спасибо!
fedonin
Сообщение fedonin » 08 сен, 2017 17:35
Кстати, там (в СИ-20), разъем программатора нестандартный, если лицом к себе, то слева - направо: 1.VDD(+5V), 2.VSS(GND), 3.MCLR(VPP), 4.DATA, 5.CLOCK. Так что, без пайки не обойтись... !!!
fedonin
Сообщение fedonin » 09 окт, 2017 18:38
Всем Доброго Вечера! Заметил один недостаток моей прошивки, как первого, так и второго варианта. При повышении входной частоты выше 10-15Hz, счетчик пропускает несколько импульсов на сотню (1-3). Проверял, подавая импульсы от генератора сразу на два счетчика - на этот и на тестовый OMRON H7C. Как я понял, это конфликт прерываний - при обработки прерывания от таймера для вывода информации на дисплей, прерывание от счета могло пройти необработанным. Я ввел дополнительную переменную, выполняющую роль флага, взводимого в 1 при появлении сигнала на входе и сбрасываемого в 0 только после обработки счета. Пропуски прекратились. Также прекратилось легкое мерцание цифр при подаче относительно высокочастотного входного сигнала. Так что, теперь наверное, следует перезалить исправленный вариант, за что прошу прощения у модераторов. -):
OWEN_V1.3.zip
(25.18 КБ) 1 скачивание
OWEN_V1.3.zip
 Удивительное »
