"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Индикатор показывает две фазы
  • Всё для электрика
Алексагдр
Сообщение Алексагдр » 23 июл, 2017 12:04
Подскажите пожалуйста. По всей квартире пропало освещение и не работают эл.приборы. Индикатор во всех розетках, освещении и счетчике показывает на нуле фазу. Отключив ноль центральный от счётчика положение не изменилось. Я так понимаю произошёл разрыв ноля. А как узнать где, в самой квартире или на центральном вводе в квартиру, не знаю. Щитов на лестничной площадке нет.
Последний раз редактировалось elhouse 23 июл, 2017 13:32, всего редактировалось 1 раз.
Причина: Добавил пробелы.
Сообщение Похожие темы » 23 июл, 2017 12:04
Видеорегистратор RVI-взломан, не показывает
Душ бьет током, тестер 40 вольт показывает
Счетчик ЦЭ 2727 показывает только один тариф
Индикатор напряжения
Re: Индикатор показывает две фазы
Сообщение elhouse » 23 июл, 2017 13:27
Прежде чем создавать тему, стоило-бы воспользоваться поиском!
Все вопросы уже давно заданы и ответы получены. Что за народ - нифига ничего не смотрят, сразу флудят.
Тема почти первая в списке раздела, неужели глаз нет? Индикатор горит на фазе и на нуле
Алексагдр писал(а):
Источник цитаты А как узнать где, в самой квартире или на центральном вводе в квартиру, не знаю.
Пригласите электрика - он знает!
Сообщение slavapril » 23 июл, 2017 14:02
Алексагдр писал(а):
Источник цитаты Отключив ноль центральный от счётчика
И незачем было...
Алексагдр писал(а):
Источник цитаты Щитов на лестничной площадке нет.
Ну, значит, щиток где-то в квартире, вестимо...
Алексагдр писал(а):
Источник цитаты как узнать где
Попробовать найти первую же коробку на вводе в квартиру (обычно - это прихожая) и определить там наличие или отсутствие нуля
Сообщение elhouse » 23 июл, 2017 16:15
slavapril писал(а):
Источник цитаты Попробовать найти первую же коробку на вводе в квартиру (обычно - это прихожая) и определить там наличие или отсутствие нуля
Скорее всего он наводку меряет - поэтому и горит на нуле. В щитке отгорел какой-то провод или автомат ёк.
Slavik85G
Сообщение Slavik85G » 05 дек, 2017 18:50
Если на щиток несколько фаз подведено - может быть вместо нуля еще одна фаза случайно подключена?
Сообщение slavapril » 05 дек, 2017 19:06
Человеческий фактор может привести к чему угодно...вопрос в том, откуда у вас такая мысль.
Slavik85G
Сообщение Slavik85G » 07 дек, 2017 12:46
Было раз что-то подобное у знакомой на работе лет 5-6 назад. Что-то у них там меняли с проводкой по кабинетам. Потом, через некоторое время, в розетку включили магнитофон, он и сгорел. Ну мало ли как бывает, взяли муз. центр, включили - результат тот же. Больше ничего не включали - вызвали электриков. Они посмотрели, в щитке покрутили и сказали - все ок. Гореть действительно больше ничего не горело. Вот отсюда и вопрос собственно говоря. Может включили сразу неправильно, а потом быстро поправили, сказали что все нормально)
andrey.kirov
Сообщение andrey.kirov » 21 окт, 2019 6:31
Добрый день. Помогите разобраться с наводкой. Возникает наводка на отдельном участке. А именно есть распред коробка, питание на которую идет сразу с автомата. В самой коробке дальше идут провода на розетку, на лампочку с выключателем, и на другую комнату. Как только подключаю лампочку с выключателем, то провод который идет на выключатель становится с наводкой. Пробовал подключить просто один провод с выключателем также показывает наводку. Откручивал выключатель, оголенные провода показыют наводку. Отключил в доме все автоматы и всю что подключено на этот автомат. Все равно показывает наподку на нуле и на земле (земля вообще откусана со всех сторон). Откуда возникает наводка? Никаких излучений уже нет, проверял лампой, индикатором и мультиметров. И как убрать ее?
Сообщение slavapril » 27 окт, 2019 17:40
Если провод никуда не подключен, то провод с фазой всегда создаст на нем наводку, достаточную для индикатора. Только потенциала на нем все равно нет. Индикатор без батарейки?
 Новое »
