"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=2e4,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div","\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0432\u0430\u043c, \u0447\u0442\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043f\u043b\u0430\u0433\u0438\u043d AdBlock \u0432 \u0432\u0430\u0448\u0435\u043c \u0431\u0440\u0430\u0443\u0437\u0435\u0440\u0435, \u0438\u043b\u0438 \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u043d\u0430\u0448 \u0441\u0430\u0439\u0442 \u0432 \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0439 (\u0431\u0435\u043b\u044b\u0439 \u0441\u043f\u0438\u0441\u043e\u043a). \u0412 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435 \u043f\u0440\u043e\u0441\u043c\u043e\u0442\u0440 \u0441\u0430\u0439\u0442\u0430 \u043f\u0440\u043e\u0441\u0442\u043e \u043d\u0435\u0432\u043e\u0437\u043c\u043e\u0436\u0435\u043d. \u0421\u043f\u0430\u0441\u0438\u0431\u043e."],["span",{id:i},"Ok, \u042f \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u043b \u0431\u043b\u043e\u043a\u0438\u0440\u043e\u0432\u043a\u0443!"]],"");n=1e3>n?200:n,"undefined"!=typeof window.localStorage&&null===window.localStorage.getItem("regainShow")&&window.localStorage.setItem("regainShow",0),setTimeout(function(){var e=document.body;e.innerHTML="",e.appendChild(p),p=document.getElementById(a);var n=Math.max(window.innerHeight,document.documentElement.clientHeight,document.body.clientHeight)/2,o=n-p.offsetHeight/2-100;document.getElementById(i).onclick=function(){window.location.reload(!0)},t(r,"body","background:#eee",4),t(r,"body > div","width:100%;max-width:650px;margin:"+(o>0?o:50)+"px auto 0;",5)},n)}catch(u){throw u}}}).call(this,"95fb86ebf0e68bd6f9bf3a499ac96ff8-798-1598425629");
13.03.2019 02:07 | Electric House 78.6
ТОП-5 лучших паяльных станций от AliExpressС каждым годом на прилавках наших магазинов появляется все более новое и технологичное электрооборудование, одно из них - это паяльная станцияДля монтажа и ремонта современной электроники все чаще применяются паяльные станции, которые завоевали большую популярность, как у профессиональных электронщиков, так и у радиолюбителей.
Паяльная станция – это комплект специализированных инструментов для выполнения операций одиночной или групповой пайки. И нужна она, прежде всего, тем, кому возможностей обычного паяльника уже мало. Например для выпайки всевозможных радиодеталей, например микросхем с большим количеством ножек.
Паяльная станция состоит из нескольких основных состовляющих -это паяльник со сменными наконечниками, которые называются жалом, основной блок электронной регулировки, подставка для паяльника, термофен, оловоотсос для удаления излишнего припоя, очистители жал.
Основным рабочим модулем паяльной станции является устройство питания с электронным или аналоговым блоком управления на основе автотрансформатора. Главными характеристиками, учитываемыми при выборе паяльной станции, являются ее мощность, комплектация, тип флюса используемого для пайки.
При проверке цен будьте особенно внимательны - некоторые из них могут быть указаны только за комплектующие и дополнительное оборудование.
Лучшая паяльная станция - YAOGONG 887D 2 в 1
паяльная станция YAOGONG 887D
Отличная SMD паяльная станция -YAOGONG 887D 2 в 1 с DC питанием и всевозможными дополнительными насадками.
Цена: от 475,34 руб. (проверить цену и скидку)
Отзывы покупателей:
Отзыв №1: Отличная станция. Сделана добротно. Рекомендую.
Отзыв №2: Очень хороший паяльник! Нагрев мгновенный. Доставили в Питер за 3 недели.
Купить на АлиЭкспресс: http://ali.pub/370chp
Лучшая паяльная станция - PJLSW 8586 700 Вт ESD
паяльная станция PJLSW 8586 700 Вт ESD
Отличная светодиодная цифровая 2 в 1 SMD паяльная станция - PJLSW 8586 700 Вт ESD с воздушным пистолетом..
Цена: от 2728,27 руб. (проверить цену и скидку)
Отзывы покупателей:
Отзыв №1: Доставка быстрая при отправке из России (Подольск). При включении на табло мигало 100, фен не грел, но дул, паяльник работал на 5. Внутри что-то гремело, словно отвалилось. На свой риск открутила переднюю крышку, оказалось вздулся конденсатор и снялся корпус. Проблема решилась заменой конденсатора. Цена вопроса 10 рублей. Всё работает идеально, температура регулируется.
Отзыв №2: Очень быстро доставили, буквально за четыре дня, правда не в руки, а до пункта доставки, до которого пришлось топать по морозу, но неважно. Станция пришла в полной комплектации, без видимых повреждений, внутрь пока не залезал. Хочется сказать, что работает хорошо, но я не понимаю, задумано ли так, что при переключении тумблера фена в положение "0", отключается только нагрев, но фен продолжает дуть? В остальном никаких нареканий пока нет, за свою цену лучше не найти, советую брать.
Купить на АлиЭкспресс: http://ali.pub/370e23
Лучшая паяльная станция - Eruntop 8586D +
паяльная станция Eruntop 8586D +
Отличная SMD паяльная станция - Eruntop 8586D + 2 в 1 с воздушным пистолетом и всевозможными дополнительными насадками. Двойной цифровой дисплей.
Цена: от 3898,59 руб. (проверить цену и скидку)
Отзывы покупателей:
Отзыв №1: Заказал 02.01.2019, получил 01.02.2019. Отправлено СДЕКом с доставкой до двери (забирал сам). Упаковка без повреждений. Комплект полный и все в рабочем состоянии. Сломана подставка для паяльника - видимо такую положили. Продавец на вопросы не отвечал. По спору вернули 700 рублей в течении 12 часов. Продавца и товар рекомендую.
Отзыв №2: Станция отличная. Поставил на 2 транзистора радиаторы. Пропаял кнопки увеличения уменьшения, пропаяно было но я посчитал мало. Температуру показывает чуть больше: Фен на 30 градусов паяльник 40. Но это лучше чем показывал меньше чем есть. За такие деньги (2900) прекрасная станция. Рекомендую к покупке.
Купить на АлиЭкспресс: http://ali.pub/370elx
Теги: паяльная станция товары из китая aliexpress
ePN Cashback - скидки
Aliexpress Cashback
Copyright © Electric House. 2005 - 2019. При использовании материалов обязательна ссылка на: Тех.поддержка | Реклама на сайте
Новый заказ на сайте
Андрей Станкевич, г.Обнинск, оставил заявку на схему электрооборудования в доме
Новый заказ в магазине
Черногребель Сергей Васильевич, г.Москва, оставил заявку на Ремонт электропроводки
