"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=2e4,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div","\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0432\u0430\u043c, \u0447\u0442\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043f\u043b\u0430\u0433\u0438\u043d AdBlock \u0432 \u0432\u0430\u0448\u0435\u043c \u0431\u0440\u0430\u0443\u0437\u0435\u0440\u0435, \u0438\u043b\u0438 \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u043d\u0430\u0448 \u0441\u0430\u0439\u0442 \u0432 \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0439 (\u0431\u0435\u043b\u044b\u0439 \u0441\u043f\u0438\u0441\u043e\u043a). \u0412 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435 \u043f\u0440\u043e\u0441\u043c\u043e\u0442\u0440 \u0441\u0430\u0439\u0442\u0430 \u043f\u0440\u043e\u0441\u0442\u043e \u043d\u0435\u0432\u043e\u0437\u043c\u043e\u0436\u0435\u043d. \u0421\u043f\u0430\u0441\u0438\u0431\u043e."],["span",{id:i},"Ok, \u042f \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u043b \u0431\u043b\u043e\u043a\u0438\u0440\u043e\u0432\u043a\u0443!"]],"");n=1e3>n?200:n,"undefined"!=typeof window.localStorage&&null===window.localStorage.getItem("regainShow")&&window.localStorage.setItem("regainShow",0),setTimeout(function(){var e=document.body;e.innerHTML="",e.appendChild(p),p=document.getElementById(a);var n=Math.max(window.innerHeight,document.documentElement.clientHeight,document.body.clientHeight)/2,o=n-p.offsetHeight/2-100;document.getElementById(i).onclick=function(){window.location.reload(!0)},t(r,"body","background:#eee",4),t(r,"body > div","width:100%;max-width:650px;margin:"+(o>0?o:50)+"px auto 0;",5)},n)}catch(u){throw u}}}).call(this,"95fb86ebf0e68bd6f9bf3a499ac96ff8-798-1598425629");
21.01.2014 09:33 | Electric House 86.2
Левый вводЗдесь представлены наиболее интересные и оригинальные способы безучетного пользования электроэнергией, которые предлагают некоторые недобросовесные электрики.
Это будет полезно знать работникам ЖКХ, ДЭЗов, ЖЭКов, СНТ и прочим жилищным структурам.
Объявим войну незаконным, левым подключениям! Электроснабжение должно развиваться, а значит труд энергетика должен быть оплачен.
Досадно, но незаконное подключение к электросети сегодня мало кого удивляет или шокирует. Складывается впечатление, что такое положение вещей постепенно становится нормой и для компаний, обеспечивающих энергоснабжение, и для потребителей электроэнергии. Кто-то может даже сказать, что для подобного развития событий есть объективные причины или предпосылки.
Например, систематический рост тарифной стоимости электроэнергии или банальное снижение платежеспособности населения и бизнеса. Не способствует улучшению ситуации и удивительная доступность способов хищения электроэнергии вкупе с несовершенством законодательной базы, которая могла бы помочь в привлечении расхитителей электроэнергии к серьезной ответственности.
Убедительная просьба нас по этим вопросам нас не беспокоить!
Способ № 1
Описание: Скрывается небольшой участок вводного кабеля, устанавливается скрытно автомат и подключается кабель от фазы ввода к фазе выхода. Например к ближайшей розетке, или распаячной коробке. Если включён автомат SA2, а SA1 выключен, то питание идёт через счётчик. А если включён автомат SA1, а SA2 выключен, то питание идёт напрямую минуя счётчик.
Схема левого ввода
Способ № 2
Описание: Для частных домов. Скрывается небольшой участок вводного кабеля. На этом участке подключается параллельно магнитный пускатель ампер на 50 (в зависимости от вашего аппетита), катушку магнитного пускателя запитать от сети дома, после счетчика и автоматов (можно использовать тиристорный пускатель он надежнее и абсолютно бесшумный). К выходным клеммам пускателя, можно подключить часть розеток в доме или отдельные токоприемники.
Схема левого подключения
Способ № 3
Описание: Данный способ проверен для однофазного электромеханического счетчика типа СО-ЭАК2М год выпуска 1994. Способ состоит в следующем: нужно мощный постоянный магнит приложить к передней панели счетчика, в области серийного номера, над болтиком. Постоянный магнит притягивает ротор шагового двигателя, в результате последний не проворачивается. Таким образом вы должны создать внешнее магнитное поле сильнее чем внутренние. Как показала практика магнит лучше брать из 25-ватного динамика. Возможно стоит поэкспериментировать над другими электромеханическими счетчиками (есть классический механический счетный механизм но нет диска, если прислушаться эти счетчики должны тикать при нагрузке) в том числе трехфазными типа СЭТ, ЦЭ, ...
Способ № 4
Описание: Индукционные счетчики имеют огромную отрицательную погрешность при наклоне 90 градусов от вертикали, панель для счетчика, изготавливается с возможностью наклона (на петле ).
Способ № 5
Описание: Между Главным Колесом механического счетчика и циферками установлен, как нетрудно догадаться, шестеренчатый редуктор.
Находим в редукторе шестеренку о десяти зубьях, после чего берем плоскогубцы типа пассатижи и нежными движениями лодыжки выламываем 9 зубьев, оставляя один. Если после этой процедуры шестеренка начинает напоминать улыбку бабы Яги, то значит, операция прошла успешно. Особо продвинутые читатели уже сообразили, что передаточное число редуктора изменится в 10 раз ! Остается только восстановить пломбу способом, описанным на сайте.
Достоинства:
- не требуется никакого вмешательства ни в электросхему счетчика, ни в подходящие-отходящие провода!
- не требуется никаких внешних заземлителей, труб и т.п., внезапное появление контролеров даже в ваше отсутствие ничем не грозит!
- ничего не обнаружит и контролер, прилипший с секундомером к Главному Колесу счетчика и обложивший квартиру калиброванными нагрузками, поскольку это Колесо будет крутиться с номинальной скоростью, соответствующей подключенной нагрузке.
- платить в 10 раз меньше намного удобнее, чем вообще не платить, поскольку это не вызовет подозрений, впрочем, особо порядочные личности могут выкусить не 9 зубьев, а 8.
Backit ePN Cashback - скидки
Aliexpress Cashback
Copyright © Electric House. 2005 - 2019. При использовании материалов обязательна ссылка на: Тех.поддержка | Реклама на сайте
