"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=2e4,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div","\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0432\u0430\u043c, \u0447\u0442\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043f\u043b\u0430\u0433\u0438\u043d AdBlock \u0432 \u0432\u0430\u0448\u0435\u043c \u0431\u0440\u0430\u0443\u0437\u0435\u0440\u0435, \u0438\u043b\u0438 \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u043d\u0430\u0448 \u0441\u0430\u0439\u0442 \u0432 \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0439 (\u0431\u0435\u043b\u044b\u0439 \u0441\u043f\u0438\u0441\u043e\u043a). \u0412 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435 \u043f\u0440\u043e\u0441\u043c\u043e\u0442\u0440 \u0441\u0430\u0439\u0442\u0430 \u043f\u0440\u043e\u0441\u0442\u043e \u043d\u0435\u0432\u043e\u0437\u043c\u043e\u0436\u0435\u043d. \u0421\u043f\u0430\u0441\u0438\u0431\u043e."],["span",{id:i},"Ok, \u042f \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u043b \u0431\u043b\u043e\u043a\u0438\u0440\u043e\u0432\u043a\u0443!"]],"");n=1e3>n?200:n,"undefined"!=typeof window.localStorage&&null===window.localStorage.getItem("regainShow")&&window.localStorage.setItem("regainShow",0),setTimeout(function(){var e=document.body;e.innerHTML="",e.appendChild(p),p=document.getElementById(a);var n=Math.max(window.innerHeight,document.documentElement.clientHeight,document.body.clientHeight)/2,o=n-p.offsetHeight/2-100;document.getElementById(i).onclick=function(){window.location.reload(!0)},t(r,"body","background:#eee",4),t(r,"body > div","width:100%;max-width:650px;margin:"+(o>0?o:50)+"px auto 0;",5)},n)}catch(u){throw u}}}).call(this,"95fb86ebf0e68bd6f9bf3a499ac96ff8-798-1598425629");
08.03.2019 06:41 | Electric House 87.9
Срок поверки электросчетчиков
Установленные в жилых помещениях приборы учета электрической энергии по закону должны периодически проходить процедуру поверки. Поверку счетчиков электроэнергии осуществляют посредством сравнения показаний счётчика с установленным эталоном. Использоваться должны только поверенные приборы учета, о чем говорится в федеральных законах №102 (Об обеспечении единства измерений) и №261 (Об энергосбережении и о повышении энергетической эффективности).
Ответственность за процедуру поверки счетчика лежит на его владельце. Счетчик необходимо доставить в ближайший центр стандартизации и предварительно согласовать дату доставки.
Согласно статье 13 №102-ФЗ средства измерений нужно своевременно представлять на поверку.
Если у владельца есть подозрения, что в показаниях нет точности, он имеет право инициировать процедуру поверки самостоятельно и раньше положенного срока.
Кто должен осуществлять плановую квалифицированную поверку электрических счетчиков? Мосэнергосбыт должен уведомлять о сроке наступления обязательной поверки и рассылать уведомления потребителям.
Поверка — платная услуга, оплачивается владельцем счетчика.
Начнём с физики прибора. Срок эксплуатации электросчетчика ограничен, даже у моделей электронного типа. Связано это с тем, что при потреблении энергии, счетчик, в отличие от большинства приборов-потребителей, находится в работе постоянно. Конечно, нагрузки невелики, даже у дисковых приборов, но согласитесь, пять лет непрерывного вращения шестерёнок и диска приведёт к определённому износу, даже если счётчик изготовлен из самых дорогих материалов.
Отсюда и возник термин – межповерочный интервал, то есть период, после которого производитель не гарантирует точности показаний. Итак, у нас есть срок службы электросчётчика (а это примерно 25 лет для большинства моделей), срок годности, а также срок гарантированной работоспособности.
Если Вам кажется что это одно и тоже, то Вы ошибаетесь. Именно для увязки этих столь разных периодов и введён срок проверки электросчетчика, который является основным для выдачи разрешения на его дальнейшую эксплуатацию. Тестовые стенды проверяют не только точность показаний, но и состояние механической части счетчиков.
Почему срок может быть условным, и какова цена вопроса
Домашний электрик без проблем своими руками может установить и подключить электросчетчик своими руками, даст советы, какой счетчик лучше и как его выбрать, а также как будет себя вести электропроводка при разных вариантах подключения. Особо одарённые могут заложить жучки, магнитики и прочую ерунду, думая что обманули энергетиков (что невозможно), обманывая себя в сумме затрат (что правда).
Чего не сможет сделать доморощенный электрик – так это проверить счетчик, произвести его поверку и выдать документ, разрешающий дальнейшую эксплуатацию.
Многие, прочитав это, воскликнут про дискриминацию и засилье энергосбытовых компаний, но мы остудим этот пыл. Дело в том, что энергосбытовая компания тоже не имеет права производить эти операции. Поэтому давайте, перечислим порядок действий в том случае, когда срок истекает:
  • Ничего не надо делать, пока энергосбыт не вспомнит, что Ваш счётчик подлежит поверке. Межповерочный интервал редко указан в договоре на поставку электричества;
  • Если у Вас есть паспорт, то помните – срок проверки электросчётчиков исчисляется от момента включения, а не от даты изготовления. К сожалению, многие региональные энергосбытовые компании грешат этой «ошибкой», вынуждая пользователей платить лишние деньги;
  • Если всё же час поверки пробил, не спешите соглашаться с навязываемой услугой энергосбыта. Нет, всё будет быстро, аккуратно и честно, но вот цена поверки может отличаться раза в два от услуг независимой сертифицированной лаборатории.
Для поверки счётчика не требуется его демонтаж и отключение питания от счётчика в дом или квартиру. Сама процедура – сверка показаний счётчика с ватт и Ом метрами в нескольких рабочих режимах. Ряд параметров одновременно контролируется мультиметром. Запугивание отключением и демонтажем счетчика не более чем рэкет энергетиков, направленный на попытку навязать более дорогую услугу. Ниже на изображен порядок поверки электросчетчика "Меркурий".
Если посмотреть на схему подключения счетчика, приложенную выше, видно, что поверку можно осуществлять без отключения от электросети.
Установленный срок поверки счетчиков — это отрезок времени, на протяжении которого показания затрат электроэнергии верны.
Срок межповерочного интервала указывают в паспорте, обычно варьируется в пределах 6-16 лет. Через сколько лет нужно снова проводить поверку, зависит от модели прибора.
Показания электросчетчика признают достоверными:
  • 8 лет — положено для механического индукционного устройства с диском;
  • 16 лет — для современных электронных счетчиков.
Периодичность поверки не должна превышать положенные сроки.
Подводные камни в бурных морях учёта электроэнергии
Не стоит недооценивать глубину проблемы, если Ваш счётчик врёт. Отделаться от энергетиков в этом случае будет довольно непросто – у них тоже есть полномочия, хотя прав куда меньше чем у Вас. Всё, что в этом случае Вы сможете оставить для себя, это замену счетчика в доме (квартире) в течение учётного периода. К сожалению, ремонт счётчиков стоит дороже приобретения и установки нового, даже если делать это своими руками.
Это и будет тот самый – условный срок продления проверки счетчика до истечения «даты». Только имейте в виду, что в таком случае отсрочка будет не больше года, 12 месяцев. После чего или придётся менять счетчик, или согласится с применением поправочного коэффициента. Или пожить с опломбированным счетчиком, показания которого будут иметься в виду, но не приниматься во внимание. С отметкой в документе – «превышен срок межповерочного интервала». Так что обратите внимание на моменты:
  1. Сохраните паспорт счётчика с печатью установившей его организации и датой ввода в эксплуатацию.
  2. Сверьте сроки поверки (они указаны на счётчике) с цифрами в паспорте.
  3. Уточните (иногда установщики ставят бесплатно штамп) дату следующей поверки.
  4. Сравните поставленную на счетчик пломбу с организацией, от имени которой пломбируется Ваш прибор.
И помните. Граница полномочий энергетиков заканчивается не у Вашей розетки или входной двери, а у счетчика. Если Ваш счётчик установлен на улице, энергетики могут Вас побеспокоить, только если Вы просто перестанете платить за энергию. Срок проверки электросчетчиков установленных вне дома – это не Ваша забота.
И вообще. Все проблемы энергетиков, которые они придумывают, чтобы выставить Вам счёт на сумму побольше, являются не Вашими, а их! Так что пусть они и беспокоятся о том, как в рамках законов получить возможность провести с Вами переговоры после осмотра счетчика.
Только не соглашайтесь сразу на всё, почитайте. Может быть, даже без юристов сможете сэкономить немало денег, не нарушая законов, в том числе нормативов межпроверочного интервала и всех остальных придуманных подзаконных актов.
Стоимость услуги
Многих владельцев интересует вопрос, сколько стоит поверка счётчика электроэнергии в 2019 году.
Положение Постановления Правительства РФ №442 от 04.05.2012 г., п.145 регламентирует, что все траты по обеспечению эксплуатации средства учета, его целостности, сохранности ложатся на плечи владельца.
Оплачивает поверку собственник счетчика. Стоимость варьируется в зависимости от выбранного учреждения.
Теги: поверка электросчетчиков проверка электросчетчиков поверка счетчиков проверка счетчиков
Copyright © Electric House. 2005 - 2019. При использовании материалов обязательна ссылка на: Тех.поддержка | Реклама на сайте
