• Актуально
Отключить рекламу X
"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Вопросы по работе форума
Здесь вы можете получить тех.поддержку по форуму, ознакомиться с информацией о форуме. А так же оставить ваше сообщение о работе форума: замечания, пожелания, предложения и т. д.
Сообщение elhouse » 23 июн 2012, 19:39
Форум заточен под комп.
Сейчас я в отпуске - осенью займусь...
Алиэкспресс по Русски | Канал на Youtube
AliExpress RU&CIS
Сообщение Похожие темы » 23 июн 2012, 19:39
О ЛЭП и их работе
Сбои в работе стабилизатора
При работе утюга срабатывает УЗО
Перебои в работе люстры
Проблемы в работе электрогенератора
Сообщение sergey_sav » 23 июн 2012, 19:54
Вообще-то, ни с мобильника, ни со смартфона особых проблем с общением на форуме не ощущалось в последнее время... Картинки не в каждое сообщение втыкаем, посему можно особо и парится... ибо стоит помнить, что между следующими фразами слишком маленькая грань...
"Сейчас чуть-чуть поднастрою и всё будет отлично"
"Блин! Что же я наделал!"
Сообщение elhouse » 23 июн 2012, 20:15
Золотые слова - зимой их все испытали...
Достаточно нечаянно (задеть кнопку на клаве) сделать лишний пробел в коде и усё - белая страница вместо форума.
И многие часы поиска косяка...
Зимой будем ломать базу, сейчас отпуск и так слишком много сделал... многие устали от этих модификаций.
Добавлено спустя 7 минут 13 секунд:
Мобильной версией совсем не занимался - модифицировал только основной стиль форума.
А мобильный так и стоит в стандарте. А проблема с кнопкой видимо косяк разработчика (зимой посмотрю).
  • Главные новости
Сообщение nikola » 23 июн 2012, 20:15
Я так и думал что форум заточен под комп. Потому что есть проблемы с быстрым ответом, через раз получается отправить сообщение. А если написал большое сообщение и отправил, то после этого можно смело чистить КуКи .В общем грузится телефон, браузер тормозит. На телефонах помощней может и все гладко, а мой современем надо менять, начинает отставать от прогресса. Спасибо что разъяснили.
Сообщение elhouse » 23 июн 2012, 20:20
Тут другая проблема - нас потихонечку начинают спамить с удалённого сервера.
Спамеры новую программу придумали - регятся не с нашей формы регистрации, а со своей (с удалённого сервера)
Надо решать...
Сообщение Дополнительно » 23 июн 2012, 20:20
Отключить рекламу X
Сообщение nikola » 23 июн 2012, 20:32
Я конечно в этом не разбираюсь, но разве нельзя от спама поставить " ввести код с картинки " при регистрации, входе.
Сообщение elhouse » 24 июн 2012, 09:13
nikola писал(а):
Я конечно в этом не разбираюсь ,но разве нельзя от спама поставить " ввести код с картинки " при регистрации , входе .
Так ведь на нашем форуме всё давно установлено и код с картинки и контрольный вопрос.
Почитайте моё верхнее сообщение повнимательней "С УДАЛЁННОГО СЕРВЕРА", а там (у них) нет ни капчи, ни контрольного вопроса.
Прогресс одим словом.
Добавлено спустя 12 часов 27 минут 57 секунд:
Появились умные БОТы - ищут ответ на контрольный вопрос через Гугл и подставляют. Знают Русский язык.
Залатал дырочку в одном из файлов Капчи "Контрольный вопрос" и соответственно усложнил сам "Контрольный вопрос".
Понаблюдаем - Что будет...
Сообщение slavapril » 24 июн 2012, 13:28
охренеть :lol: ...другого слова не знаю
Сообщение elhouse » 24 июн 2012, 13:41
Пока тихо...
Ни на одном из форумов нет БОТовских регистраций.
Граница на замке. Надолго ли?
Сообщение slavapril » 24 июн 2012, 13:48
Как гласит закон физики - на каждое действие всегда есть противодействие. Как боролись программисты друг с другом, так и будут. Тут главный принцип - быть на шаг впереди...ну, или хотя бы на полшага :))biggrin
 Новое »
  • Интересные новости
Вернуться в «Тех.поддержка»
