• Актуально
Отключить рекламу X
"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Вопросы по работе форума
Здесь вы можете получить тех.поддержку по форуму, ознакомиться с информацией о форуме. А так же оставить ваше сообщение о работе форума: замечания, пожелания, предложения и т. д.
Бонис
Сообщение Бонис » 29 июн 2009, 21:03
Скажите пожалуйста, на всех форумах есть кнопочка Новые сообщения, т.е. отображает те сообщения, которые я еще не читал с определенного момента.
На этом форуме есть нечто аналогичное, но не совсем. Это Найти сообщения с Вашего последнего посещения. Недостаток его заключается в том, что, если мне отобразило например десять тем, в которых появились новые сообщения, но я из них прочитал только два и вынужден был выйти по каким-либо причинам, то в следующий раз я эти восемь оставшихся тем уже не найду. Найдутся только те, которые появятся в промежуток с последнего посещения.
Можно ли это как-нибудь исправить? Считаю, что это важно.
AliExpress RU&CIS
Сообщение Похожие темы » 29 июн 2009, 21:03
О ЛЭП и их работе
Сбои в работе стабилизатора
При работе утюга срабатывает УЗО
Перебои в работе люстры
Проблемы в работе электрогенератора
Сообщение sergey_sav » 29 июн 2009, 22:50
На счёт исправить, этот вопрос нужно адресовать админу, ибо связано это с движком форума.
Посоветовать могу следующее. Кликните на "Список форумов Электрик Хаус", справа появится список "Последние затронутые темы форума"
Бонис
Сообщение Бонис » 30 июн 2009, 00:08
Попробую.
  • Главные новости
Сообщение миш » 30 июн 2009, 13:52
У меня другой вопрос. Как изменить почтовый ящик? Ядекс почта у меня не работает, есть ещё mail ru.
Сообщение sergey_sav » 30 июн 2009, 14:23
В профиле
Сообщение Дополнительно » 30 июн 2009, 14:23
Отключить рекламу X
Сообщение elhouse » 30 дек 2009, 01:48
Исправлять ничего не надо, всё давно реализовано и функций на форуме в разы больше, чем на любом другом форуме. Просто вы не умеете им пользоваться.
Иконки непрочитанных тем всегда будут для вас оранжевого цвета. Если вы их не открывали, то они так и останутся оранжевыми...
Дело было не в бабине...
Алиэкспресс по Русски | Канал на Youtube
Сообщение sergey_sav » 01 июн 2010, 21:25
На форуме сварщиков через радикал фото черта можно всунуть удобно очень.
Там тоже не беспредельный сервер и ограничения есть.
Тут, как впрочем, на любом форуме можно воспользоваться "услугами" стороннего ресурса, например, Для просмотра ссылки необходимо зарегистрироваться! или Для просмотра ссылки необходимо зарегистрироваться!. Загрузил фотку, а на форум ссылку (BBCode: Картинка в тексте или Превью - увеличение по клику)
Сообщение ВИТАЛИЙ ЙЙ » 01 июн 2010, 22:44
Юра - зайди на тот сайт(ifotki) и попробуй, почитай, всё подробно и легко.
У меня получилось с 2 раза!
А если по внимательнее подойти к этому вопросу, то получится с первого!
Сообщение ВИТАЛИЙ ЙЙ » 02 июн 2010, 05:47
На счет вина - дело хорошее, открою карту, посмотрю где Ваш город находится!
Вот и отлично! Сергею стаканчик тоже надо налить, он первый этот сайт предложил с пояснениями на второй раз!
Сообщение elhouse » 05 июн 2010, 07:32
yura писал(а):
На форуме сварщиков через радикал фото черта можно всунуть, удобно очень.
Значит у них не форум, а помойка...
У нас говно-хранилища набитые рекламой и содержащие вирусы типа "радикала" запрещены!
yura писал(а):
Раньше фото вставлял спокойно, а сейчас пишет не больше 600/800 пикселей или типа того, в чем проблема ребята?
Это стоит защита от дурака - который пытается засунуть в форум картинку весом в несколько Мб и размером больше самого форума (плакат).
Вам понравится если я вам в квартиру загоню танк?
Да и место на сервере стоит денег и оно ограничено, сервер не резиновый...
Поэтому и ограничили.
Сейчас эту функцию усовершенствовали, теперь картинка уменьшается при загрузке автоматически.
 Новое »
  • Интересные новости
Вернуться в «Тех.поддержка»
