• Актуально
Отключить рекламу X
"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Как проверить наличие наряжения
Сообщение миш » 25 июн 2009, 19:28
Как проверить наличие напряжения на схеме.
Дома собрал схему на выходе схема должно быть 900в.сунулся а у меня прибор до 750. может кто-то подскажет.
AliExpress RU&CIS
Сообщение Похожие темы » 25 июн 2009, 19:28
Как проверить АВР?
Как проверить землю
Проверить курсач
Чем проверить автоматы на ток?
Как проверить кабель без мегера?
Сообщение sergey_sav » 25 июн 2009, 19:56
Если кратко, то с помощью добавочного резистора.
Сообщение миш » 25 июн 2009, 19:58
извините но уже проверил . результат меня устроил правдо он ещё неконечный.
  • Главные новости
Сообщение миш » 30 июн 2009, 19:39
кто то меня спрашивал про схему это связано с эл.счетчиком.
Как проверить наличие наряжения - 6-1.gif (3 КБ) 4249 просмотров
Сообщение haramamburu » 30 июн 2009, 20:32
повторим вопрос:
kokoko писал(а):
Если не секрет: зачем Вам почти 1000 В?!
Рыбу глушить?
ващето схема 2, енто классический умножитель напряжения применяемый в телевизорах...
тока где выход напруги в данной схеме, и зачсем 2ф на вход.
вторая схема пральная, но не факт что она должна выдавать то, что ва хочите (какая нагрузка?), но я понял смысл: 310*3 -::
Сообщение Дополнительно » 30 июн 2009, 20:32
Отключить рекламу X
Сообщение haramamburu » 30 июн 2009, 20:45
упс... я изначально не понял вопроса...
почему то подумал Што не "выдает", оказалось измерить.
как советовал sergey_sav, вряд ли получится (еси неразумно, то ваще неполлучится (а ведь НАРОД поймет буквально - косяк спишет на ВАС "неразумного" - я не обижаю), R вольтметра должен был бы соизмерим "буквально" с СОПРОТИВЛЕНИЕМ), здесь надо применять метод "потенциометров" , 2 или более резисторов соед. послед. к нагрузке, волтметр должен с внутренним R на порядок более, вольтметр соед. парал. с резистором и умножим на кол. резисторов
ЗЫ свыше 2х кВ вольтметр свой - искоровой
Сообщение sergey_sav » 30 июн 2009, 21:12
haramamburu писал(а):
как советовал sergey_sav, вряд ли получится ...
Странно, но именно по этому принципу и строится многопредельный вольтметр -: Поэтому сказал не просто "резистор", а
Сообщение sergey_sav » 30 июн 2009, 21:15
Автору темы. Готовьтесь к взрыву. Вы взяли электролиты с малым рабочим напряжением!
Сообщение haramamburu » 30 июн 2009, 21:18
Сообщение haramamburu » 30 июн 2009, 21:20
да вряд ли, здесь как начальной школе, работает +. :F
ЗЫ здесь не должно быть Електролитов, Ваще!!!
 Новое »
  • Интересные новости
