"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Допуск по электробезопасности, зачем он и где получить?
  • Всё для электрика
Сообщение elhouse » 11 июл, 2015 2:34
Когда вы долгое время не работаете по специальности, допуск к работе может оказаться не действительным. На работу, обычно, принимают с дипломом об окончании учебного заведения, где вы обучались на электрика (электромонтера, электромонтажника). Заработную плату платят исходя из разряда, который указан в дипломе. Но зачастую в объявлениях по трудоустройству мы видим — требуется электрик с 2, 3, 4-ой группой электробезопасности, или еще лучше с действующей группой допуска. Зачем?
Давайте для начала определимся, что такое допуск по электробезопасности и для чего он нужен?
ЭТО УДОСТОВЕРЕНИЕ о проверке знаний правил и норм работы в электроустановках.
То есть диплом электрика подтверждает профессию, а допуск это удостоверение которое позволяет вам самостоятельно производить работы в электроустановках. Диплом не нужно подтверждать, отучились, получили (разряд действует всю жизнь), а группу допуска требуется подтверждать раз в год. Когда Вы после обучения (например в ПТУ) приходите на производство, то не имеете права самостоятельно работать. Вы так сказать еще не полноценный электрик и должны подтвердить то, что Вы можете работать в электроустановках самостоятельно, не подвергая себя и других опасности.
С момента получения допуска Вы сами несете ответственность за свою безопасность во время работы. В этом и заключается его сущность.
После выдачи на руки, при дальнейшей работе, Вы должны всегда носить его с собой, чтобы в случае проверки предъявлять его сотруднику соответствующих органов. Если при подобного рода проверки выясниться, что Вы самостоятельно работаете в электроустановке и не имеете соответствующей группы допуска по электробезопасности, то на предприятие наложат штрафные санкции. Размеры штрафов мне не известны, не сталкивался, если кто знает, буду признателен за дополнения в комментариях.
Получив допуск вы должны ежегодно подтверждать его, проходя проверку соответствующих знаний по электробезопасности. Если же вы не будете работать по профессии в течении 3-х и более лет, то ваше удостоверение и присвоенная группа по электробезопасности, станут не действительными. Придется все осваивать с нуля.
На каждом предприятии в независимости от того, есть ли у вас допуск с прошлой работы или нет, вы должны пройти обучение в соответствии со спецификой предприятия и получить новый.
Так что требование — с действующей группой допуска, не совсем правильное. На мой взгляд работодатель хочет этим сказать, что ему нужен специалист с опытом работы, знающий правила электробезопасности.
После окончания ПТУ я устроился работать по специальности на птицефабрику. Первое удостоверение с 3-ей группой по электробезопасности, я получи спустя 0,5 года работы. Он дал мне не только право самостоятельно производить работы, но и двигаться вперед по жизни. Получив его я понял, что имея диплом 4-го разряда и допуск, я являюсь специалистом и всегда смогу найти работу в этой области. Я сразу же уволился с птицефабрики (так как очень мало платили, и место жительства меня не устраивало) и уехал работать в другой город. Работу нашел без проблем.
Где получить допуск по электробезопасности?
В наше с вами время можно как купить документ по электробезопасности, так и пройти официальное обучение. Самый простой вариант, это купить. Но зачем? Что это даст? Ответ прост — НИЧЕГО, а то и глупое положение. Покупая, вы не получаете знаний и рискуете как своей безопасностью, так и окружающих. Подумайте над этим. Кроме того рискуете попасть в глупое положение, если работодатель вдруг что-то спросит, а вы не бум бум. Можно пройти платное обучение электробезопасности, но опять-же зачем? Придя на производство (как написано выше), придется получать новый. Так незачем тратить свои деньги на это!
Получить допуск к работе с электричеством можно на предприятии, если есть диплом. Но если у вас и диплома нет, то рекомендую, как минимум, пройти обучающие курсы. Помните, что с электричеством шутки плохи и отнеситесь к этому посерьезнее.
Сообщение Похожие темы » 11 июл, 2015 2:34
Нужен ли допуск для работы с электроустановками?
Экзамен по электробезопасности
Группы электробезопасности школа
Группы по электробезопасности 2013г
Наряд-допуск (наряд)
Re: Допуск по электробезопасности, зачем он и где получить?
Сообщение миш » 11 июл, 2015 21:09
Я уже года четыре не проходил перездачу.
Сообщение slavapril » 12 июл, 2015 8:00
Интересное у тебя предприятие ;;1):
Сообщение миш » 12 июл, 2015 10:55
Раньше каждый год сдавали, теперь я не знаю , что происходит.
Сообщение electrohoz » 12 июл, 2015 19:58
Я каждый год. Вот и в этом году в августе буду проходить обучение и сдачу экзаменов, на допуск 4гр. АТП с провами ОПР до 1000В.
Обучение 5500 рублей.
Сообщение electrohoz » 17 сен, 2015 12:55
Вот, свеженькое удостоверение получил.
Сообщение slavapril » 17 сен, 2015 15:42
А обмыть ???
Сообщение electrohoz » 17 сен, 2015 16:49
slavapril писал(а):
А обмыть ???
Мне пока нельзя, я на антибиотиках. kefir
А вы пожалуйста. _:als :)))drinks
Александр2
Сообщение Александр2 » 24 ноя, 2015 20:49
Работаю по совместительству специалистом по охране труда в клининговой компании ; руководство предлагает обучиться в ростехнадзоре на 3гр. электротехнического персонала для присвоения мной 1гр работникам. Вопрос: специалист по ОТ может присваивать 1 гр или, как вариант, ввести в штат должность « инженер» ? и на него оформить 3гр ? А если удостоверение купить?
Сообщение electrohoz » 25 ноя, 2015 8:44
п.1.4.4 ПТЭЭП, ПОТ РМ-016-2001, ПУЭ.
Вы конечно можете и купить, но я бы вам, рекомендовал отучиться.
Место обучения например: НОУ ЦДПО «Тушинский учебный комбинат» стоимость обучения.
Правила Технической Эксплуатации Электроустановок потребителей (до 1000В) - 36ч. обучение - 3800 ₽.
 Удивительное »
