"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Неисправности электронной схемы светильников НБО ЖКХ-04
  • Всё для электрика
gavryha
Re: Неисправности электронной схемы светильников НБО ЖКХ-04
Сообщение gavryha » 05 апр, 2015 14:19
Мы берём по 610. 2000 дорого. Спасибо за подсказку.
Сообщение Похожие темы » 05 апр, 2015 14:19
Справочник инженера электронной техники
Неисправности и ремонт электродвигателей
Неисправности электрических машин
Неисправности электродвигателей - поиск и устранение.
Ремонт светильников
Сообщение slavapril » 05 апр, 2015 15:56
В итоге за 2000р дешевле, чем несколько раз менять по 610р. Но это не мое дело. Вам там виднее...
gavryha
Сообщение gavryha » 05 апр, 2015 16:13
Возможно. Я просто электрик. Спасибо.
Запрещала
Сообщение Запрещала » 01 ноя, 2015 16:57
В тех светильниках, что попадали мне, выходят из строя диоды моста. Можно, как вариант поставить плату с выключателя акустического СЗВО. 4. К Платы абсолютно идентичны. Нужно только развернуть фоторезистор. Установка дополнительного инфракрасного датчика не всегда оправдана - есть мертвые зоны, особенно при установке на лестничных площадках. Чуть позже постараюсь выложить принципиальную схему.
Запрещала
Сообщение Запрещала » 16 ноя, 2015 15:32
Добрый день! Высылаю, как обещал, схему светильника ЖКХ-4.
Микросхема DD1 CD4011BM 4 И-НЕ (К561ЛА7, но в корпусе SO14)
Диоды VD1, VD4-VD7 M5 600В 1А
Стабилитрон VD3 5.6В
VT1 BC847 45В 100мА h21 200-450
Q2 BT258-800R 800В 8А Упр. вкл. 0.4В 50 мкА
Запрещала
Сообщение Запрещала » 02 дек, 2015 16:48
Проверку платы удобно производить, подав плюс постоянного напряжения (стабилизированное, нестабилизированное, выпрямленное, от аккумулятора,от батареек) через резистор в точку соединения R1 и катода VD3 (например 12В и 1 КОм). "На местности" удобнее подпаяться к соответствующему выводу R1. Минус к катоду Q2. Включенному состоянию светильника соответствует 0.5В на коллекторе VT1, выключенному состоянию соответствует 0В.
При подаче напряжения должны появиться 0.5В на коллекторе VT1, и , через время выдержки, на коллекторе появляется 0В. Если это условие выполняется, закрываем фоторезистор (даже пальцем -всего 12В!), на выводе 2 DD1 напряжение плавно уменьшается с 5.6В до 2.5В, затем скачком меняется до -0.4В. При громком звуке напряжение на выводе 2 DD1 скачком изменяется до 5.6В и начинает плавно уменьшаться. Если все происходит так, как описано, отпаиваем наши 12В, проверяем диоды и тиристор, заменяем неисправные и пробуем включать в сеть 220В.
Если плата на 12В работает некорректно, то либо выкидываем ее за неимением времени (желания, деталей, опыта), либо проверяем дальше, начиная с проверки напряжения 5.6В на стабилитроне VD3. Если питание соответствует, проверяем напряжение на выводе 10 DD1. При комнатном освещении должно быть 5.6В, при закрывании фоторезистора падает до 0В. Далее действовать по принципу "война план покажет". Удачи!
dodor
Сообщение dodor » 13 мар, 2016 5:32
А как увеличить время работы светильника?
Запрещала
Сообщение Запрещала » 13 мар, 2016 12:26
Попробуйте увеличить номинал резистора R11. Можно заменить конденсатор C4 на большей емкости, но в этом случае тоже желательно увеличить сопротивление R11. Если нет опыта паяния, лучше поручите это более квалифицированному товарищу. В схеме R11 чип-резистор 0805 (0.125 Вт) 576 КОм, C4 25 В 100 мкФ.
 Интересное »
