"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Можно ли электронный счетчик обмануть?
  • Всё для электрика
Re: Можно ли электронный счетчик обмануть?
Сообщение миш » 09 дек, 2014 18:28
Слово врать вставлено не случайно дабы не смущать других людей к способу ограничения учета электроэнергии.
Aleksei35 писал(а):
то могут использовать магнит. Однако это со временем проявиться перекосом счётного механизма или выходом из строя счётчика.
Лет так через 10 об этом узнаешь, после вскрытия прибора. -):
Сообщение Похожие темы » 09 дек, 2014 18:28
Вопрос про электронный счетчик
Электронный 3-х фазный счетчик
Электронный счетчик остановился. Причины?
Какую мощность считает электронный счетчик
Электронный балласт для люминисцентных ламп
Aleksei35
Сообщение Aleksei35 » 09 дек, 2014 18:38
Может и совсем не узнаю, смотря какой магнит потребитель подберёт. Были случаи 1-2 месяца и счётчик на помойку с перекошенным механизмом. Наверное очень жадные были очень хотели "экономии" эл. энергии поэтому магнит по мощнее и вперёд. А счётчик не обязательно вскрывать, и так будет видно.
Сообщение electrohoz » 09 дек, 2014 18:59
К чему демагогия?
Давайте конкретно.
gavryha
Сообщение gavryha » 07 июн, 2015 16:51
Нужно побывать в доме. Если в доме стоит дополнительный щит, то "О" легко отключается автоматом. И подключается контур заземления, вкопанный в огороде.
drow
Сообщение drow » 02 авг, 2015 7:14
Подскажите пожалуйста вот по какому вопросу:
Известно, что если старый советский еще счетчик подключен не правильно (перепутаны ноль и фаза), то если поставить в цепи розетку таким образом,что бы фазу она брала из линии, а ноль из вбитой в землю арматуры, то именно эта розетка счетчиком учитываться не будет ( счетчик мерит "0", а он получается "левый"). Вопрос - с новыми электронными многотарифными счетчиками это работает точно так же, или их как то научили определять слишком большие разницы в нулевом и фазном проводах и как то об этом сигнализировать (отключаться, моргать лампочками и тд.)?
Спасибо!
Сообщение миш » 03 авг, 2015 10:32
Тема воровства не обсуждаются.
drow
Сообщение drow » 05 авг, 2015 19:21
а это не тема воровства, а тема можно сказать противодействия воровству, если Вам будет угодно. Так как я считаю, что Мосэнерго, протолкнув закон, обязавший меня оплачивать замену счетчика, который я не имею права установить сам, а обязан заказать установку от Мосэнерго, стоимостью 5 т.р, и разославший после принятия этого закона всем извещения о необходимости замены счетчика (хотя срок его "годности" по паспорту истек за несколько лет до принятия закона, и они должны были произвести замену за свой счет по тем правилам, но не стали) тем самым ворует мои деньги. И компенсировать это я могу только "украв" обратно... При этом мне запрещается поставить счетчик в квартиру, он должен стоять обязательно на лестничной клетке, и в случае если кто то его сломает или снимет, я опять должен буду за свой счет оплатить Мосэнерго его повторную установку и так по кругу (это не придирки, а официальный ответ, на мой запрос)... Если есть другие варианты, как с этим можно бороться - с радостью готов выслушать.
Сообщение slavapril » 08 авг, 2015 6:37
Off Topic (флуд)
Да ладно. Если вы украли велосипед у своего соседа или незнакомца в отместку за свое несчастливое детство, это не значит, что вы не вор.
Счетчики всю жизнь подлежали замене по истечении срока поверки. А в последнее время еще и по причине запрета использования таковых с классом точности 2,5 и обязательной их замене на класс не более 2.0 (постановление за №530 от 31 августа 2006 г. и постановление правительства РФ от 4 мая 2012 г. №442). Счетчики должен менять их балансосодержатель. В основном, это владельцы квартир. Хотя иногда это может быть и домоуправление, и ТСЖ.
Расположение счетчиков указано в проекте на дом. Перенести можно по согласованному заявлению с обслуживающей организацией. Случаи воровства в практике были. Насколько помню (это были 90-е) жильцы прикладывали справку из милиции и заявление о переносе.
Счетчик можно и не менять. В этом случае предусмотрено нормативное начисление согласно типа дома и количества прописанных(постановление управления энергетики и тарифов вашей области). Например, для Липецкой области это так
свет.xls
(106 КБ) 31 скачивание
свет.xls
drow
Сообщение drow » 08 авг, 2015 6:54
Если я забрал велосипед у своего соседа, в счет того, что он не отдает мне долг равный стоимости велосипеда - нет, не украл.
РАНЬШЕ счетчик должен был менять его балансосдержатель, а теперь его должен менять собственник помещения, которое этот счетчик обслуживается, как раз с 2012 года вроде. И странное совпадение, у моего счетчика срок поверки истек еще в 2006 году, но никто его не менял, так как он стоит на балансе мосэнергосбыта. И через пол года после выхода закона,пришло письмо о необходимости замены за свой счет. Совпадение? подключение 2-х проводов и опломбирование по цене 2500 - нормально? И не надо говорить что на клещи ставящие пломбу нажимает СПЕЦИАЛИСТ, потому это столько и стоит... Если бы можно было самому поставить счетчик, а его опломбирование происходило бесплатно, при плановой проверке щитков, то вопросов бы небыло... Но о какой мы проверке говорим.. никто же не ходит и не затягивает винты на клеммах с алюминиевыми проводами, как должно быть вообще то... А все это включено в тарифы... и их никто не снижал после перекладывания финансовой ответственности на получателя услуги.
Сообщение slavapril » 08 авг, 2015 7:42
Таким поступком Вы как бы пытаетесь взять на себя функции судебных приставов. И знаете, что не правы ибо хотите воровать тайно, а не в открытую.
По теме:
Установка нового счетчика включает в себя демонтаж старого, возможную необходимость замены или перезачистки проводов, монтаж нового, проверка правильности подключения (для однофазных выглядит смешно - но всё же), опломбировка, составление акта ввода в эксплуатацию (а это тоже человекочасы ;;1): )
Приходилось как-то менять трансформаторы тока и общедомовой счетчик в ТСЖ. Каждая из этих процедур стоит в ЛЭСК 6000р и 5000р соответственно. Всего 11000р. Причем в прайсе проверка правильности подключения и опломбировка стоят всего 1120р и 1120р соответственно. Всего 2240р. Всё остальное - это цена демонтажа-монтажа и т.д. Менял я сам подешевле. А ЛЭСКу и отдали-то всего-то 2240р.
Я это к тому, что вам надо поинтересоваться, что входит в предлагаемую вам цену. Если счетчик - теперь уже ваша собственность, вы имеете право сами его заменить(привлечь специалиста). А вам должны только проверить правильность подключения и опломбировать.
Если же вы хотите, чтоб вам заменили просто так в счет того, что когда-то там по вашему мнению (я этого не знаю) должны были и без вас сделать, то придется подобаться с вашим Мосэнерго. Но это все равно накладно хотя бы по нервам.
Но как бы там ни было, ваша позиция "отберу и всё тут" - это на ваш страх и риск.
Так что ищите компромисс. Узнавайте.
 Новое »
