"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Можно ли электронный счетчик обмануть?
  • Всё для электрика
Rash3000
Сообщение Rash3000 » 01 дек, 2014 4:44
СНТ, вывел счетчики на столбы, владельцы живут круглогодично, но потребление по счетчику небольшое, даже по сравнению со мной, я бываю по выходным и у меня нагорело больше, знаю что в основном сидят на электрокотлах. Счетчики электронные Энергомера, однофазные, пошел мерять клешами днем и намерил :1 счетчик - ток в нулевом совпадает с фазным, на 2 счетчике - на нулевом 16, на фазном 25, на 3 счетчике - на нулевом 0, на фазном 30.
Спрашивается - у двоих какие то манипуляции с нулевым проводом и можно ли электронный счетчик обмануть и как доказать что владельцы неправильно поступают?
 ! Сообщение от: elhouse
Информация для Роскомнадзор! В данной теме обсуждается несанкционированное воровство электроэнергии и методы его обнаружения. Давайте все вместе обсудим, как обнаружить воровство электричества и как доказать, что электричество воруют!
Сообщение Похожие темы » 01 дек, 2014 4:44
Вопрос про электронный счетчик
Электронный 3-х фазный счетчик
Электронный счетчик остановился. Причины?
Какую мощность считает электронный счетчик
Электронный балласт для люминисцентных ламп
Re: Можно ли электронный счетчик обмануть? И как доказать что воруют?
Сообщение nikola » 01 дек, 2014 10:51
Скрытое содержание (только для VIP-пользователей)
Rash3000
Сообщение Rash3000 » 01 дек, 2014 11:59
Сообщение electrohoz » 01 дек, 2014 17:33
Rash3000 писал(а):
что электронный счетчик обманывается также как и механический
Счётчики сами покупали или хозяева участков?
Если хозяева покупали, то они могли обратиться, к нехорошим людям и переделать их!
Важная информация:
Rash3000
Сообщение Rash3000 » 01 дек, 2014 17:41
Счетчики сам покупал, в целях борьбы и вижу что битва то неравная, мне бы обосновали -ток в нулевом должен быть равен фазному или нет.
Сообщение electrohoz » 01 дек, 2014 17:55
Вообще то нагрузка меряется на Фазном проводе!
Сообщение миш » 01 дек, 2014 19:50
Для начала, ток вы мерили правильно. Раз на нулевом проводе есть ток, то ноль подключен.Индикатор то же будет моргать но реже. Интересно, питание в дом трех проводное или двух проводное. Электронный счетчик обманываеться легко. Первое, что вы определили отсутствия ноля на счетчике. Это есть причина посмотреть правильность подключения и так же правильно ли хозяева используют ноль. Имееться ввиду подключен ли ноль в доме.
Сообщение electrohoz » 02 дек, 2014 5:53
Надо устанавливать счётчики, которые не только по фазе считают, но и по нолю.
И самому производить монтаж.
Сообщение миш » 02 дек, 2014 7:16
Я конечно могу и незнать, что существуют счетчтки которые считывают только фазу. Но питание однофазных счетчиков осуществляется с помощью фазы и ноля. Если на счетчик не приходит ноль то и работу счетчика можно назвать не правильным. То есть воровством.
Сообщение electrohoz » 02 дек, 2014 7:40
Счётчики, старого образца. Примеры и принцип работы приводить не буду, дабы не приучать, наш народ к воровству!
В своё время, сам иногда пользовался этим, пока не поставили современную систему учёта электроэнергии.
 Новое »
