"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Освещение на 36 Вольт
Консультации и обсуждение электромонтажа, электропроводки, электроснабжения, обустройства освещения в гаражах, торговых, производственных и прочих нежилых помещениях. (Только для членов клуба и VIP-пользователей). Как вступить в "Клуб электриков" и стать VIP-пользователем?
  • Всё для электрика
Иван111
Сообщение Иван111 » 01 май, 2014 3:55
Здравствуйте уважаемые коллеги. Помогите решить проблему.Никогда не сталкивался с освещением на 36 вольт. Понижающий трансформатор 380/36 тсзи-6.3кВт . 80 светильников с лампами накаливания 60 Вт. Трансформатор первичка звезда вторичка треугольник . з фазы подключил без нуля на выходе вторички 3 фазы без нулевого контакта межфазное напр. 36Вт . Подключил кабелем 6 квадрат (магистральный). 20 светильников на Фазы А и В. включил - работает. На фазы В и С подключил второй группой таким же сечением еще 20 светильников. Началась проблема кабель 6 квадрат от трансформатора до до распред щитка с автоматом с низкой стороны сильно греется и автомат по истечении минут 20 высекает. Вопрос в том что от катушек первички до клемного болтика на тексталитовой гребенке транса идет тоже 6 квадрат. Почему идет нагрев? не пойму. Хотя и мощность транса позволяет. И почему на вторичке нуль отсутствует? То что ток при меньшем напряжении возрастает в разы я рассчитывал и получил результат сечения требуемого кабеля 25 квадрат. но ведь 6 квадрат на фазе от обмотки до болта. Помогите разобраться. :F
Точнее как подключить эти 3 фазы что бы транс загрузить киловатт на 5 и что бы не было проблем?
И что будет естли вторичку в звезду соединить? Может поможет. Экспериментами не занимался транс дорогой больно
Сообщение Похожие темы » 01 май, 2014 3:55
Освещение в подвале на 36 вольт
12 вольт от 220 вольт
Re: Освещение на 36 Вольт
Сообщение Калямба » 01 май, 2014 5:57
Так на первичке ток в 10 раз меньше...потому и не греется.
Иван111 писал(а):
Почему идет нагрев?
На вторичке с 20 лампами 60х20=1200 Вт /36 в = 33,3 А. Подключили 2 ю группу к жиле "Б" 33+33=66 А ....для 6 мм/кв явный перебор...сами-же посчитали
Иван111
Сообщение Иван111 » 01 май, 2014 6:26
Извиняюсь.от катушек вторичной до клемного болтика на тексталитовой гребенке транса 6 квадрат.
Сообщение Калямба » 01 май, 2014 8:29
Кабель медный? На группы ламп медь или алюминий?
Иван111
Сообщение Иван111 » 01 май, 2014 8:36
да. И транс и кабель медь
Сообщение Калямба » 01 май, 2014 8:56
и с катушек до клеммника тоже 6 квадрат...одинаковое сечение провода до клеммника и после него - один греется - другой нет. Остается грешить на качество кабеля - попробуйте заменить. Стоит еще учесть: если до клеммника одиночные провода, а в кабеле все 3, и еще в общей оболочке - нагрев будет больше.
Иван111
Сообщение Иван111 » 01 май, 2014 9:13
Греется все что к вторичной обмотке относится
Добавлено спустя 6 секунд:
Вопрос почему тогда выхода катушек 6 квадрат если паспортные данные дают 6 киловатт. Почему идет нагрев? Раз сделали 6 киловатт значит он должен вывозить. А он 40 ламп не вывозит и греется и такое чувство сгорит. Я огнетушитель рядышком уже поставил.
Сообщение Калямба » 01 май, 2014 9:24
это вопрос к производителю. Для 6-ти квадрат приемлемо 46А. Примерно 14-15 ламп в каждой группе.
Кстати, а сами вторичные катушки греются? Чем выполнены?
Сообщение Anatoliy » 01 май, 2014 9:44
И будет греться. Сечение кабеля от Транса до РЩ нужно увеличить. Как минимум должна быть 10 если не 16.
И 80 ламп вы уж никак не поставите на 3 кВт транс.
Иван111
Сообщение Иван111 » 01 май, 2014 15:12
Транс на 6 киловат
 Интересное »
