"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Как запитать от сети 220В всякие автоприбамбасы на 12В
  • Всё для электрика
KvadraNT
Сообщение KvadraNT » 25 ноя, 2012 13:39
Мне, как и многим автовладельцам наверное, часто дарят всякие автомобильные устройства с питанием от прикуривателя на 12В. Но иногда возникает желание использовать эти устройства дома. Каким образом это осуществить? Достаточно ли будет купить любой адаптер питания с 220В на 12В, прикрутить к нему гнездо, подобное прикуривателю и втыкать в него эти устройства?
Сообщение Похожие темы » 25 ноя, 2012 13:39
Подключение дачного домика к сети 220В.
Запитать газовый котел.
Как правильно запитать/расчитать?
Можно ли запитать подсветку на шкаф от выключателя?
Посоветуйте, пожалуйста, как запитать фитнес-клуб.
Re: Как запитать от сети 220В всякие автоприбамбасы на 12В
Сообщение Pukin » 25 ноя, 2012 13:43
Запросто. Необходимое условие - это что бы мощность блока питания (адаптера) была выше мощности вашего устройства. ;;1):
KvadraNT
Сообщение KvadraNT » 25 ноя, 2012 14:01
Сразу возникла куча вопросов.
1. Как мне определить мощность моего устройства? Н/р у меня насос на 12V. Максимальный ток потребления 15А. Про мощность производитель ничего не указал.
2. Как определить мощность адаптера/блока питания, если у них та же не указана мощность, а указано только: Вход 220В~50Гц, выходное напряжение 12В, выходной ток 1000mA
Сообщение sergey_sav » 25 ноя, 2012 14:20
1. Данных о максимальном токе достаточно. 15А
2. Тут тоже достаточно данных о токе, 1А
3. Таким образом, источник питания нужен в 15 раз сильнее, по крайней мере...
KvadraNT
Сообщение KvadraNT » 25 ноя, 2012 14:42
Ну я типа чайник в этих вопросах, можно поконкретней с пояснениями. Привожу параметры нескольких автоприбабмбасов, а Вы посоветуйте готовое решение. Итак: насос- 12В, макс.ток потребления 15А, пылесос- 12В, мощность 137Вт, ток потребления неприводится, автохолодильник- 12В, мощность 65Вт, минимойка 12В, 60Вт, видеорегистратор и автотелевизор, автовентилятор-известно только то, что питаются от прикуривателя, остальные электрические характеристики не приводятся. Через какой прибор все это запитать в домашних условиях?
Сообщение Pukin » 25 ноя, 2012 14:58
KvadraNT писал(а):
Итак: насос- 12В, макс.ток потребления 15А, пылесос- 12В, мощность 137Вт, ток потребления неприводится, автохолодильник- 12В, мощность 65Вт, минимойка 12В, 60Вт, видеорегистратор и автотелевизор, автовентилятор-...
У меня в квартире меньше бытовой техники :))biggrin
Из Вашего списка самая большая мощность - у насоса 12В х 15А =180 Вт. Поэтому Вам нужен блок питания не менее 200 Вт. Идете в магазин и просите блок питания 220В/12В (например, для диодных ламп или типа того) с мощность не менее 200Вт или током не менее 200Вт/12В=16А
KvadraNT
Сообщение KvadraNT » 25 ноя, 2012 15:15
Я правильно понимаю, что адаптер надо подобрать для устройства, у которого самая большая мощность или самый большой ток потребления, а остальные устройства и так будут работать от этого же адаптера?
И еще, не хотелось бы самому эксперементировать, но что будет если насос 12В с током 15А запитать от блока питания 220В/12В 5А. ?
Сообщение Pukin » 25 ноя, 2012 16:49
Выйдет из строя т.е. сгорит адаптер
KvadraNT
Сообщение KvadraNT » 25 ноя, 2012 17:06
А если к блоку питания 220В/12В дающему ток 15А подключить девайс 12В с током потребления 1А, девайс не сгорит случайно?
Сообщение Pukin » 25 ноя, 2012 17:11
Нет, не сгорит, будет выдавать 1А, а 14А останутся в запасе ;;1):
 Интересное »
