"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Перестали работать розетки, а свет есть!
  • Всё для электрика
bond007
Сообщение bond007 » 26 апр, 2012 11:17
Всем привет! Нужна помощь в выявления неисправности.
Сегодня утром окончательно перестали работать все розетки во всех 3-х комнатах, за исключением кухни и коридора. Свет работает везде.
А началось все со вчерашнего вечера, на секунды электричество в розетках в 2-ух комнатах начало пропадать (погасли телики, и компы), потом пропало минут на 20, и снова восстановилось. В районе часа ночи я был за компом, оно снова начало пропадать, но уже на какие-то миллисекунды (как буд-то вот вот все отключится) даже такое характерное шипение в колонках появилось и фильтр в аквариуме, было слышно, работал прерываясь.
После я выключил комп, и более менее все восстановилось. На утро я включил комп проверить почту, он даже загрузится не успел, все вырубило сек через 10 после запуска, с тех пор, уже 2 часа не работает не одна розетка не в одной из комнат. И больше не восстанавливается. Сейчас комп на кухне - тут все ок.
Первым делом я смотрел щиток, дергал все 3 автомата вверх-вниз, никаких изменений, только свет реагирует. Потом отключил практически все приборы в комнатах с китайскими удлинителями. Кто-то писал на форуме может быть сломан автомат, я замерил отверткой детектором сверху и снизу переключателя на клемах - фаза горит. видимо дело не в нем, дом 16ти этажный, лет 20-25 давности, проводка изначальная. Куда копать и в чем может быть еще дело?
Сообщение Похожие темы » 26 апр, 2012 11:17
Свет включается, розетки не работают.
Перестали гореть несколько лампочек
Перестала работать розетка
Как подобрать реле что бы заставить работать светофор
Разделить свет
Re: Перестали работать розетки, а свет есть!
Сообщение elhouse » 26 апр, 2012 11:30
На форуме это уже описывалось и не раз:
На Кухне в розетках пропал ноль
Воспользуйтесь поиском по форуму.
Алиэкспресс по Русски
PavelP-y
Сообщение PavelP-y » 26 апр, 2012 13:04
Индикатор в розетках что показывает?
Сообщение elhouse » 26 апр, 2012 13:14
Смотри контакты проводов в розетках.
Morigan
Сообщение Morigan » 26 апр, 2012 13:26
В первую очередь проверь контакт на нулевой шинке в щитке и на АВ.
bond007
Сообщение bond007 » 26 апр, 2012 13:31
Ничего не показывает, во всех розетках кроме кухни - ноль сигнала.
Сейчас займусь, прочитал в интернете насчет-
В очень многих домах для экономии проводов строители делают проводку на розетках так: от автомата идёт провод на первую розетку, от первой на вторую и т. д.. В таких домах ко всем розеткам (кроме последней) подходят два провода. Нужно в первую очередь вскрыть крышки розеток (предварительно отключив автомат) и проверить целостность соединений на каждой розетке и подтянуть клеммы розеток, обычно отгорание видно визуально.
Т.е. получается схема подобна елочной гирлянде? Когда 1 лампочка перегорает, не работает вся гирлянда.
Слишком технически, не электрик, если можно другими словами.
PavelP-y
Сообщение PavelP-y » 26 апр, 2012 13:55
Если у Вас стоят однополюсные автоматы, то должна быть колодка, к которой подходят все нулевые жилы. Определяется визуально, может иметь вариации. Но если индикатор ни чего не показывает в розетках, то этот вариант практически исключается.
bond007
Сообщение bond007 » 26 апр, 2012 15:07
Ура!! Есть продвижение! Раскрутил последнюю розетку находящуюся на кухне, а там!!
Провод фазы окислен с углевым налетом, прилегал к металлической пластине старой розетке и замыкал на ноль на другом конце, развел их отверткой с громким скрежетом искр, не понимаю, как эта розетка вообще могла работать. Сейчас соединил (завтра купим новые розетки и закреплю хорошо клемами).
В одной комнате розетки заработали!! А в 2ух последних нет (приборы не пашут), но в них появилась теперь фаза (замерил индикатором), видимо исчез ноль? :lol: Куда он мог деться?
Ага, есть такая колодка.
Morigan
Сообщение Morigan » 26 апр, 2012 15:25
Поаккуратней! Можно и без глаз остаться, а то и ... Перед тем как лезть в розетку отключите автоматы!
Если бы вовремя отключили автоматы ноль бы сейчас не искали.
Прямо реалити-шоу "Как не специалист борется с электричеством". Выживет или не выживет ;;1):
Сообщение nikola » 26 апр, 2012 15:32
Посмотрите в коридоре распредкоробку. Возможно отгорела фаза, должна быть оплавленная изоляция. Пора вам делать ревизию своего электрохозяйства.
 Новое »
