"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Re: переделка автоматических выключателей
Сообщение ВИТАЛИЙ ЙЙ » 27 дек, 2011 17:24
забанют за такое ---обратись в личку
Сообщение Похожие темы » 27 дек, 2011 17:24
Логика срабатывания автоматических выключателей
протоколы о проверке работоспособности автоматических выключ
Переделка счетчика СИ-20 OWEN
Переделка проводки в квартире
Сообщение миш » 27 дек, 2011 17:28
cherneff писал(а):
ограничения по мощности 9 квт
9 кВТ это на 3 фазы это не плохо.или у вас электрическое отопление?
Сообщение sergey_sav » 27 дек, 2011 18:11
Переделка ИЭК, Декрафт, ЭКФ без заводской опрессовки опытный человек заметит. Переделка АВВ практически не заметна, но стоит втрое дороже. Оно точно Вам надо?
Может просто добровольно тему закроем?
Alipapa
Сообщение Alipapa » 28 дек, 2011 8:34
Проще аккуратно подделать надпись на корпусе автомата. Поэтому лучше ищите не электрика, а художника.
mangoose
Сообщение mangoose » 06 янв, 2014 17:56
ИЭК, ЭКФ не самый лучший выбор. Разве что ЭКФ ВА47-100 и на 125А в качестве основного рубильника. а в своей щитовой нормальные автоматы поставить. Переписать тоже не проблема шесть лет рисую. Кстати по вопросу переборки ничего видно не будет!
Сообщение sergey_sav » 06 янв, 2014 21:44
А прочитать сообщения двухгодичной давности (чуть выше) религия не позволяет?
mangoose
Сообщение mangoose » 07 янв, 2014 8:55
Позволяет! Читал. Вот только я занимаюсь уже шесть лет переборкой и так называемой маляркой! Последние автоматы например ЭКФ - дрян.. неимоверная. Да еще галограмму клеют на заклепки. Малярка помогает! Могу и фото поделиться. А сообщение написал так как не хочется чтобы тема форума умерла!!
Сообщение electrohoz » 07 янв, 2014 9:21
Считай, что разместил бесплатную рекламу на форуме, оказываю незаконные услуги по переделки автоматических выключателей.
И жди в гости, товарищей с погонами.
А если серьёзно, сейчас такие счётчики умные пошли, их то как ты переделаешь?
В них залита программа по отключению, при превышении нагрузки.
И в случаи проверки электросчётчика, энергетики узнают, когда и что было изменено!
jonny241
Сообщение jonny241 » 07 янв, 2014 13:41
Через несколько месяцев, после такой установки, Товарищи поставят свой автомат на столбе (вверху), до Вашего отвода, и он будет отключаться раньше, Вы будете их постоянно вызывать и платить деньги (обычно, после второго раза).
mangoose
Сообщение mangoose » 07 янв, 2014 14:02
Давай по порядку (в том числе с юридической точки зрения)!
1. Кто сказал что услуга не законная! Кто-то что-то ворует?!!!! НЕТ! Я уже 6 лет этим занимаюсь! И в интернете полно моих обьявлений. Есть даже 2 сайта!!! И я не скрываюсь. Переделать можно бензопилу на лодочный мотор - НЕЗАКОННО? Или я может где-то по своей практике закон не дочитал? Скинете ссылочку хотябы по админке?!!
2. Насчет счетчиков тоже интересно. Хотелось бы для Вашего красного словца модельку услышать и желательно где их серийно устанавливают!
3. Насчет энергетиков. Около 40% моих заказчиков - инженеры тех.аудита.
Подитожу.
Предположим что Вы живете в частном доме и у Вас на фасаде дома стоит опломбированый прибор учета (электрический счетчик) вместе с автоматом. Если у Вас договор с РЭС на 3КВт то автомат у Вас на 16 ампер (3,5КВт) и больше номинал Вам ставить не хотят (да и врядли поставят) а Вам хочется. Очень хочется, а иногда и необходимо хоть кратковременно включить несколько эл. приборов с общим потреблением скажем 4КВт. Ваш автомат обязательно сработает и его нужно заново включать (а со временем его параметры «сядут» и срабатывать он будет уже не на 3,5 КВт а на 2КВт) и очень скоро Вы не будете стоять с калькулятором и считать общую нагрузку.
Переделанный автомат не влечет за собой хищение эл. энергии, а позволяет Вам брать больше, причем оплачивая её по счетам!!! Проверить подлинность автомата без вскрытия не сможет даже сотрудник завода, где он сделан. А инспектор РЭС, какие проблемы если даже когда-то что-то всплывет? Повторюсь - ВЫ что-то украли?!!! В самом худшем случае поменяют автомат на необходимый (а может такой-же по их незнанию - заряженный)
Кому интересно - задавайте вопросы, отвечу всем!
Добавлено спустя 4 минуты 58 секунд:
На столбе ставят не автоматы, а ограничители тока!!!
Кто будет лазить по столбам когда у Вас произойдет КЗ или просто по перебору сработает!
Ограничители тока я тоже переделываю!
Если Вы хотите блеснуть своими знаниями - не получится! "Ехидничество"мне и не интересно!
Кому действительно нужна помощь из сложившейся ситуации (когда хочется взять больше эл. энергии.) В том числе с юридическим сопровождением помогу Всем!
Кому интересно - задавайте вопросы!
 Удивительное »
