"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Сделал проводку проводом ПВС (что делать?)
  • Всё для электрика
zin
Сообщение zin » 29 ноя, 2011 18:28
Здравствуйте .
Я 15 лет работаю электриком много сделал производственных объектов и вот только сейчас узнал что провод ПВС нельзя использовать для проводки . Так пишет большинство. Странно мы его ставили почти везде и в трубах и лотках и коробах и никаких проблем не было.По своему опыту знаю что электрики его уважают за его легкий удобный монтаж и гибкость.
Сейчас сделал частный дом весь ПВС ом что теперь делать ломать стены выковыривать? ПОСОВЕТУЙТЕ . Можно ли ставить узо на проводку сделанной ПВСом где прочитал что возможны ложные срабатывания.
Также мне интересно если нельзя ставить ПВС как же заводить жесткий провод в розетку сечением 3х4 ? Пвс легко ставится а жесткий врядли влезет.
На освещение тоже нельзя ствить ПВС? А что делать если при замене выключателя жесткий провод обломится под корень ? Какая альтернатива ПВС?
Сообщение Похожие темы » 29 ноя, 2011 18:28
Проблема с проводом утюга
Управление несколькими фонарями одним проводом
Обогрев мини-теплички проводом Tash
Каким проводом заменить часть проводки в квартире
Попал саморезом в проводку
Сообщение sergey_sav » 29 ноя, 2011 20:44
zin писал(а):
...только сейчас узнал что провод ПВС нельзя использовать для проводки
Про ПВС и про то, почему он не предназначен для стационарной проводки можно прочесть на страницах форума (поиск). Поэтому на эту тему повторяться не стоит.
Сейчас сделал частный дом весь ПВС ом что теперь делать...
Если делали для себя, то и решать Вам, как поступить. Если делали для заказчика, то стоит призадуматься о гарантийных обязательствах. Если заказчик случайно узнает, чем ему сделали проводку, когда будут закончены отделочные работы, то претензии могут превысить разумные пределы... Однако, и тут решать Вам, оставить работу, выполненную с нарушениями нормативных требований, или переделать сейчас.
Мне тоже интересно, с какой целью понадобилось заводить в бытовую розетку провод 3*4?... Вот 3*2,5 (а более и не требуется) в розеточку заводится нормально, хотя и не скажешь, что легко, как 3*1,5.
Стационарные линии освещения ничем не отличаются от прочих и на них распространяются теже требования.
Среди гибких проводов, удовлетворяющих требованиям сегодняшних нормативов, разумной альтернативы не встречал в нашей местности... Подходящим можно считать ВВП2 нг (LS), водится на Украине.
Сообщение FRIM@N » 30 ноя, 2011 13:37
На заводе тоже очень много слеплено ПВСом,правда не скрыто.Очень СИЛЬНО дымит прри КЗ
zin
Сообщение zin » 03 дек, 2011 11:04
Честно говоря не видел что б ПВС дымил а тем более горел.(хотя дымить я думаю будет любой кабель если его перегрузить и защита не работает)
У нас он стоит везде . Стоит даже на улице и в мороз и в жару работает как миленький только изоляция внешняя пожелтела . Закупают только его с жестким не связываются .Мне кажется его специально занижают чем он плох? тем что называют его проводом а не кабелем?
Сообщение haramamburu » 03 дек, 2011 11:08
Тем, что он не предназначен для стац. прокладки - подробней о назначении , на сайте производителя
Сообщение sergey_sav » 03 дек, 2011 13:00
Вот тут немножко есть... Немного порассуждаем о проводах...
И тут чуток... Кабель/провод какой марки Вы используете?
Сообщение FRIM@N » 03 дек, 2011 17:09
сечение 2.5 КЗ -защита 100А автомат
Сообщение sergey_sav » 16 дек, 2011 8:25
vas1963 писал(а):
Неужели я сделал,что-то не так?
Если что-то в начале темы изложено не понятно, извините.
В свете Вашего вопроса, приведу только три выдержки.
Нормативные требования. ПУЭ, изд.7
2.1.48. Провода и кабели должны применяться лишь в тех областях, которые указаны в стандартах и технических условиях на кабели (провода)
А теперь посмотрим...
Провод ПВС ... предназначен для присоединения электроприборов и электроинструмента по уходу за жилищем и его ремонту, стиральных машин, холодильников, средств малой механизации для садоводства и огородничества и других подобных машин и приборов, и для изготовления шнуров удлинительных ...
Провода марки ШВВП предназначены для присоединения радиоэлектронной аппаратуры, приборов микроклимата, электропаяльников, кухонных электромеханических приборов, светильников, стиральных машин, холодильников и других подобных электрических приборов, используемых в повседневной жизни, а так же провод ШВВП применяются для изготовления удлинительных шнуров...
Ну и ещё одну для сравнения
Назначение кабеля ВВГ, ВВГнг, ВВГнг-ls состоит в распределении и передачи электрической энергии в стационарных установках, для фиксированного монтажа силовых цепей, цепей упрвления и местного освещения на номинальное переменное напряжение до 1 кВ частоты 50 Гц. Данные кабели наиболее широкое применение получили в монтаже электропроводки жилых и промышленных объектов.
Если сравните и увидите разницу, то ответ найдёте самостоятельно.
(для упрощения сравнения, кое-что выделил жирным)
Сообщение sergey_sav » 16 дек, 2011 9:01
"Присоединение приборов". Под этой фразой подразумевается "шнурок", который торчит из прибора (СМ, телевизор, чайник) и на его втором конце вилка для подключения к розетке.
Про удлинитель итак понятно... Удобен или нет ШВВП для удлинителя, вопрос спорный, ибо области применения могут быть различны.
Что же до провода, уложенного в кабель канал, то если Вы в него уложили удлинитель, то он таковым и останется.
Это к вопросу о терминологии.
А что до споров... так вроде в них и рождается истина. -):
Сообщение sergey_sav » 17 дек, 2011 18:19
vas1963 писал(а):
Вся проводка сделана мной в проводе ПУНП 1,5*2; 2,5 *3; 3,5 *3
Помимо того, что ПУНП "не есть гут", имеется эксклюзивное сечение 3,5... :)))
 Новое »
