"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Смазка подшипников электродвигателей
  • Всё для электрика
LIKHAC
Сообщение LIKHAC » 19 мар, 2011 15:55
Подскажите пожалуйста, какой смазкой лучше всего смазывать подшипники небольших электродвигателей, мощностью до 400ват? Спасибо.
Сообщение Похожие темы » 19 мар, 2011 15:55
Замена электродвигателей
Ремонт электродвигателей.
Защита 3-х фазных электродвигателей
ABB автоматы защиты электродвигателей.
Неисправности и ремонт электродвигателей
Сообщение Anatoliy » 19 мар, 2011 16:33
Цеатим.
Смазка в которой капля падения выше 100 градусов.
На смазке это указано.
Сообщение Василич » 19 мар, 2011 17:02
В зависимости от конструкции подшипника и числа оборотов электродвигателя:
Подшипник скольжения - латунная/бронзовая втулка с фетровой прокладкой - высокооборотные исполнительные двигатели, например в автомобилях - жидкая смазка "машинным" маслом (Ц20), лучше всего чистым трансформаторным маслом;
Подшипники скольжения без фетровой вставки - низкооборотные - графитовая смазка (автомобильная) или самодел (1/3 ЦИАТиМ 201/солидол + 2/3 графита со щеток), кстати удобная и нужная вещь при монтаже цепей сильных токов;
Подшипники качения/шарикоподшипники - ЦИАТиМ201/солидол(технический вазелин, белый как мармелад); ЦИАТиМ202/тавот (от темно-синего до почти черного цвета) или лучше, но дорого - автомобильная литиевая смазка;
Для подшипников высокоточных механизмов, как правило сверх-высокооборотных и с малым моментом на валу стоит поискать специальную литиевую на силиконовой основе смазку - такую, как применяют для смазки игольчатых подшипников в крестовинах авто.
Жидкие смазки проливают до пропитки фетра и не более, излишки засыхают в зазоре статор/ротор и могут заклинить двигатель; густые смазки - не более 2/3 объёма подшипниковой камеры - учитывая расширение при разогреве/работе
Looking
Сообщение Looking » 20 мар, 2011 13:05
Хороший ответ.)
А у нас не предприятии только литол)))) А вообще пользуемся закрытыми подшипниками)) Там сразу и смазка есть...)
Сообщение Василич » 20 мар, 2011 14:41
Закрытые подшипники тоже требуют тех.ухода! - промывки и смазки 10-15% объема.
Looking
Сообщение Looking » 20 мар, 2011 15:24
Эм, дак есть же разные закрытые.....,)
Leart
Сообщение Leart » 15 авг, 2012 11:10
LIKHAC писал(а):
Подскажите пожалуйста , какой смазкой лучше всего смазывать подшипники небольших электродвигателей , мощностью до 400 ват ? Спасибо.
Molykote BG-20
Большинство электродвигателей являются быстроходными, поэтому одной из проблем таких механизмов является подбор смазки для опорных подшипников.
Не каждый смазочный материал способен сохранять свои рабочие характеристики в эксплуатационных условиях электродвигателя. Смазка для опорных подшипников должна обладать достаточно высоким скоростным коэффициентом. Надежную защиту опорных подшипников в тяжелых условиях эксплуатации обеспечивает смазка Molykote BG-20 от Dow Corning.
Сообщение FRIM@N » 15 авг, 2012 15:18
У нас такая же история, но есть версия что в подшипниках смазка консервационная, даже если и не так то там ее кот наплакал, все равно разбираем и мажем.
ЕВГЕНЬЕВИЧ
Сообщение ЕВГЕНЬЕВИЧ » 04 сен, 2015 11:01
Чтобы не открывать новую тему хочу спросить чем смазывается втулки двигателя кондиционера БК 2000 2ДАК 71-40-10-У2 .Кондиционеру лет 30, но рабочий,смазка высохшая. Старую твердую массу удалил промыл втулки.
Re: Смазка подшипников электродвигателей
Сообщение elhouse » 04 сен, 2015 12:00
Универсальная смазка для всего, что вертится - "Литол"
Если подшипник не разборный:
Берёте металлическую ёмкость, кладёте туда подшипник и Литол.
Ставите на плиту.
Литол от нагрева станет жидким и проникнет внутрь подшипника.
После охлаждения застынет.
Алиэкспресс по Русски
 Новое »
