"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Как проверить межвитковое замыкание обмоток двигателя?
  • Всё для электрика
jovani
Сообщение jovani » 12 фев, 2011 4:46
Вчера на работе гудел двигатель мощностью 37квт, при проверке не обнаружил дефекты, все 3 фазы приходят на обмотку двигателя, схема соединение треугольник, обмотки тоже проверял все в норме запаха тоже не было и отправил на мастерскую с подозрением на витковый. Вопрос как можна определить если катушка витковая?
Заголовок отредактировал, а-то не понятно о чём речь.
Сообщение Похожие темы » 12 фев, 2011 4:46
Разные напряжения обмоток генератора
Короткое замыкание
Замыкание в электроплите!
Как узнать где происходит замыкание?
Замыкание дверного звонка
Looking
Re: Как узнать витковую обмотку двигателя?
Сообщение Looking » 12 фев, 2011 7:14
Мне кажется или что-то не договаривается?
Не понимаю, что за "витковый" или "витковая"?
Сообщение elhouse » 12 фев, 2011 7:37
А разве бывают другие? Сообщение похоже на Квест!
Сообщение sergey_sav » 12 фев, 2011 8:08
Имеется в виду витковое замыкание обмотки.
Автору, гарантированно определить наличие виткового по звуку не возможно... лучше прибором.
jovani
Сообщение jovani » 12 фев, 2011 8:22
Да витковая замыкания! Я и проверял мегомметром всё в норме!
Сообщение sergey_sav » 12 фев, 2011 8:42
Мегером можно проверить замыкание обмоток на корпус, но никак не витковое замыкание обмоток.
Re: Как проверить межвитковое замыкание обмоток двигателя?
Сообщение Anatoliy » 12 фев, 2011 9:08
Лучше конечно на такие двигатели ставить Реле контроля двигателя.
А в ваших условиях можно проверить
1. Клещами по току.
2. По сопротивлению обмоток.
Но смотря какое витковое, бывает что определить сложно,
Только на стенде обмотчиков.
Сообщение Василич » 12 фев, 2011 10:59
Есть еще очень древний способ: Внутрь статора (т. е . разобрав двигатель и удалив ротор с подшибниковыми щитами) подключенного на пониженное напряжение вносят стальной шарик на нитке к державке - при витковом он будет тормозится по центру поврежденной катушки. Осторожно, при быстром внесении шарика может выстрелить как из электромагнитной пушки по касательной к осо двигателя
Сообщение миш » 12 фев, 2011 17:25
Василич просто скажу браво этот способ стар но действеный. я думал онем забыли.
Anatoliy писал(а):
1. Клещами по току.2. По сопротивлению обмоток.
jovani
Сообщение jovani » 14 фев, 2011 17:19
Алексей_Е писал(а):
есть еще причина гудения-пропадает фаза,кто обслуживал знает когда на одной из фаз плохой контакт то при включении нагрузки провод может приянуться к шпильке двигателя а во время работы из-за вибрации может пропадать контакт двигатель работает на двух фазах но гудит
Ну да это понятно но не в этом случай потому что я проверял все контакты и шпильки были в хорошим состояние!!!
 Интересное »
