"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Ремонт шуруповёрта интерскол модель ДА-12ЭР-01 нужен совет
LIKHAC
Сообщение LIKHAC » 25 янв, 2011 16:03
Добрый вечер. Нужен совет по ремонту щуруповёрта.
Сегодня сломался шуруповёрт! Перестала работать трещётка (а может как по другому называется, незнаю).
Трещит и шурупы не закручивает. Вопрос 1-ый Есть-ли шанс починить? 2-ой как добраться до этого узла? 3 ий как снять патрон (он там на конусе или закручивается как-то?).
Большое спасибо за ответы.
Сообщение Похожие темы » 25 янв, 2011 16:03
Как восстановить аккумулятор шуруповерта?
Возможность переделки аккум. шуруповерта на AC
Модель диммера / чем заменить
Дизель-генератор, что за модель?
Дифавтоматы ИЭК в квартиру: какую модель выбрать?
Re: Ремонт шуруповёрта интерскол модель ДА-12ЭР-01 нужен совет
Сообщение FRIM@N » 25 янв, 2011 16:43
дистанционно вряд ли кто так сразу скажет,кроме тех кто лично ремонтировал
Сообщение sergey_sav » 25 янв, 2011 16:48
LIKHAC писал(а):
Вопрос 1ий Естьли шанс починить?
Вскрытие покажет. Могли просто проточиться канавки, где сидят сухарики. Если шурик дорогой, то есть смысл самостоятельно изготовить держак сухариков (слесарка)
2ой как добраться до этого узла?
Разобрать шуруповёрт.
3 ий как снять патрон(он там на конусе или закручивается как-то?
При полностью убранных губках вывернуть винт с левой резьбой внутри патрона
Сообщение sergey_sav » 25 янв, 2011 16:57
Версия (навеяло...)
А трещётку можно повернуть вправо по максиму?
LIKHAC
Сообщение LIKHAC » 25 янв, 2011 18:09
sergey_sav писал(а):
Версия (навеяло...)
Можно только эфекта нет.
LIKHAC
Сообщение LIKHAC » 25 янв, 2011 19:14
Всем спасибо за участие,шуруповёрт атремонтирован! Дело было в переключателе скоростей (он там как оказалось механический) кольцо становилось чуть наперекос и недовключала ни 1ю ни 2 ю скорость. Проблема решена с помощью надфиля.
 Удивительное »
  • Всё для электрика
