"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Ложные срабатывания датчиков движения
  • Всё для электрика
Re: Ложные срабатывания датчиков движения
Сообщение slavapril » 04 янв, 2011 10:44
Датчик, как известно, реагирует не просто на инфракрасное излучение, а на перемещение или изменение этого излучения. И если у вас рядом труба отопления, от которой перемещается теплый воздух или идут из ванной теплые пары воды, то вполне возможно и ложное срабатывание. Это во-первых......Во-вторых, если у вас датчик с регуляторами, возможно, вы просто достаточно его не вывели из тестового режима. Нужно "методом тыка" отрегулировать чувствительность по свету, по дальности и по чувствительности к инфракрасному излучению(т.е. к объектам). К тому же хотелось бы знать, 2-х проводной он у вас или 3-х проводной? Какова его мощность(в плане подключаемой нагрузки) и с какой лампой он у вас по факту работает?
Сообщение Похожие темы » 04 янв, 2011 10:44
Количество пожарных датчиков
электронную можно схему подключения датчиков EDC Bosch MC 5
Время срабатывания УЗО
Возвращаясь к причинам срабатывания УЗО ...
Анализ причин срабатывания УЗО.
azat
Сообщение azat » 11 июл, 2013 9:47
У меня датчик LX21B&C стоит в коридоре квартиры ,тоже ложно срабатывает часто,кошек собак нет, как убавить чувствительность? ,
там только 1 переменник по времени ,больше никаких регуляторов ,разбирал до платы как убавить чувствительность ?
Сообщение elhouse » 11 июл, 2013 9:51
Поменять на другой, с регулировками. Регулировок должно быть три.
Алиэкспресс по Русски
azat
Сообщение azat » 11 июл, 2013 9:55
нет ли возможности самому вклинится в плату и установить переменик?
Сообщение sergey_sav » 11 июл, 2013 12:10
Перед тем как лезть в схему, стоит выяснить причину ложняков. Может и не из-за чувствительности ДД, а из-за наводок в сети он срабатывает.
Сообщение slavapril » 11 июл, 2013 14:26
Лучше, конечно, как вам и сказали выше, хотя бы впредь брать только с тремя регулировками.
Во-вторых
Возможно, при включении-отключении, например, холодильника срабатывает - это к примеру.
Ну, а в-третьих, видывал кулибинцев, которые просто-напросто заклеивают часть сенсора датчика скотчем, уменьшая угол обзора (если причина в этом). Диковато, но кстати говоря, метод срабатывает. Может показаться смешным, но можно в качестве эксперимента попробовать в один слой ровно наклеить скотч на всё окно сенсора. Возможно(ИМХО), чувствительность и упадет, если дело в ней, конечно.
Но вот, все-таки, идея sergey_sav мне пригляднее. Хотя быть может всё -):
Looking
Сообщение Looking » 11 июл, 2013 15:30
Это приведения?) -:
Сообщение nikola » 12 июл, 2013 5:26
Looking писал(а):
Это приведения?) -:
Может тараканы.
А в первом случае - может вентилятор.
azat
Сообщение azat » 12 июл, 2013 12:28
всем спасибо за советы проверю все способы описанные
 Новое »
