"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Дюралайт
  • Всё для электрика
Zhenis
Дюралайт
Сообщение Zhenis » 29 ноя, 2010 2:52
Здравствуйте, мне нужно подключить одноцветный дюралайт, 3 цвета по 80 метров на улице. Как мне рассчитать нагрузку чтобы не выбило автомат и не поплавился дюралайт, розетка и провода?. По сколько метров резать дюралайт, и можно ли будет подключить все одной розетке или к разным розеткам? И здесь немаловажно выбрать сечение провода для подключения. Примерное энергопотребление дюралайта 16-26 Вт/пог.м. Слышал что дюралайт надо резать каждые 15 метров для уменьшение нагрузки.
Дюралайт
Сообщение Похожие темы » 29 ноя, 2010 2:52
Светодиоды. Дюралайт
Сообщение Василич » 29 ноя, 2010 12:51
Дюралайт режется кусками длиной не более 12 м.п. из-за больших потерь напряжения при больших длинах - отсюда и число кусков для вашей схемы, а для одного куска минимум 1,5 мм2 (хотя по току сильно недогружено). Подключать через специальные прокалывающие наконечники и только через блок управления (у некоторых производителей дюралайт питается постоянным/выпрямленным напряжением 220В и тогда еще пирдется соблюдать полярность).
В хорошем магазине все это должны рассказать и подобрать всю комплектацию! - не знают -не берите у них - толку не будет!
Zhenis
Сообщение Zhenis » 30 ноя, 2010 2:44
Уже поздно, дюралайт купил, намотал, теперь нужно подключить. В магазине не смогли объяснить, если подключить как они сказали то можно сделать пожар или КЗ. На каждые 12 метров покупать блок управления? Или несколько кусков по 12 м. в один блок управления? (хотя наверно блоки управления рассчитаны на какую то мощность). По какой схеме подключать рис.1, рис.2? может у Вас есть своя версия? Ну допустим я узнаю в магазине или в другом месте как подключать дюралайт, но появится еще один который не знает как это делать, обратно будет задавать вопросы, ломать голову, а так прочитает ответ на форуме и не будет задавать лишних вопросов. Кстати в интернете схему подключения я не нашел (нашел но не то).
(29.79 КБ) 8325 скачиваний
Сообщение Василич » 30 ноя, 2010 11:46
В зависимости от мощности блоков управления, имеющихся у поставщика - как правило схема 2, но немого модифицированная: от блока управления магистраль с отпаечными коробками, а от них к отрезкам дюралайта.
Сообщение sergey_sav » 30 ноя, 2010 14:05
Озвучили бы тип шнура, может какая инфа и попадалось...
Мне как то со шнурками везло... что ни привозили, все с прямым включением в 220В, хоть и резали.
Zhenis
Сообщение Zhenis » 01 дек, 2010 19:11
Дюралайт обычный, обыкновенные лампочки накаливания, одноцветный. Мне сегодня в одном заведении сказали что ее можно соединять прям на 220В. , но в конце лампочки будут гореть тусклее и вилка (я его назвал штырёк) которая подсоединяется в дюралайт, будет греться. Чтобы не грелся штырёк, дюралайт надо обрезать примерно по 20 метров и тогда штырёк греться не будет и никаких дополнительных блоков ненадо, кроме 220 В, если в сети стабильное напряжение. И все куски по 20 метров можно соединить все в одну розетку (паралельно), я думаю их нужно несколько штук по 20 метров соединить в несколько розеток и нагрузки меньше и Новый Год встретим без пожара и жертв. ВОТ. {!}
Re: Дюралайт
Сообщение FRIM@N » 01 фев, 2011 17:41
Дюралайт, который бы работал напрямую от 220 В мне не попадался.
есть такой я из него гирлянду когда-то делал 4 разноцветных куска по 1 метру
LAMER
Дюралайт
Сообщение LAMER » 25 июн, 2011 14:25
Добрый день. отрезал дюралайт не по метке, теперь не светится полтораметровый конец. как можно сделать чтоб он зажегся?
Looking
Re: Дюралайт
Сообщение Looking » 25 июн, 2011 15:35
Эм, а можно поподробней?
LAMER
Re: Дюралайт
Сообщение LAMER » 25 июн, 2011 18:28
Было 36 метров тройного дюралайта зеленого цвета, была поставлена задача разделить на две части чтоб было красиво возле бассейна. Одна часть с права заворачиватся буквой "Г" потом разрезать чтоб был проход на дорожке, и вторая часть слева от второго блока питания. Я разрезал на нужные мне две части (забыл что нужно резать строго по 2 метра по меткам). После включения та что с лева пол метра конец не горит, та что справа полтора метра не горит. Вопрос ка можно исправить такую неисправность?
 Новое »
