"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Подключение эл.двигателя
Валериан
Сообщение Валериан » 10 сен 2010, 23:02
Соотношение между переменным и выпрямленным напряжениями для различных схем выпрямления вполне определенные. Можно попробовать переделать схему выпрямления - трехфазную мостовую на трехфазную нулевую или на однофазную.
Но прежде необходимо расчитать напряжение для различных вариантов.
Сообщение Похожие темы » 10 сен 2010, 23:02
Подключение асинхронного двигателя ТМ-42/8-6-4-2
Двойное подключение двигателя.
Подключение асинхронного двигателя 160 квт
Подключение асинхронного двигателя 2АД-10/16-2/45А2УХЛ4
Подключение эл.двигателя стиральной машины ARDO
Валериан
Сообщение Валериан » 11 сен 2010, 10:41
Как это с какого перепуга?
Соотношение между переменным и выпрямленным напряжениями для различных схем выпрямления вполне определенные. Тут не надо замерять, достаточно взять калькулятор, справочник и посчитать.
И зачем конденсатор если схема выпрямления мостовая трехфазная. При такой схеме пульсации небольшие и конденсатор ни чего не решит. Другое дело если бы схема была однофазная, одно- или двухполупериодная.
Сообщение Дополнительно » 11 сен 2010, 10:41
Отключить рекламу X
Валериан
Сообщение Валериан » 11 сен 2010, 15:12
Андрей Я писал(а):
Где про это все можно почитать - поисковиком искал, но там все поверхностно :-) ?!?!
А такие формулы вам известны Ud=K x Uл или Ud=K x Uф
где: Ud - напряжение на выходе выпрямителя
Uл, Uф - линейное и фазное напряжение
К - коэффициент, зависящий от схемы выпрямления
В интернете этого я пока не видел, иначе бы сразу подсказал где посмотреть, но это можно взять в справочниках. Например: Справочник по проектированию электропривода, силовых и осветительных установок, под ред. Я.М.Большама, 1974г.
  • Главные новости
RandoM
Сообщение RandoM » 11 сен 2010, 20:07
Схему моста проще переделать(если обмотки транса звездой соеденены)с двухполупериодной на однополупериодную, используются только три диода, на катоды фазы цепляете, аноды вместе соединяете, получается + , а минус будет на нулевом проводнике. При входном ~ напряжении 220в на выходе будет около 240в постоянки
Сила, брат, в Амперах..
Валериан
Сообщение Валериан » 11 сен 2010, 22:33
"вот Валериан написал что формулу знает ну напиши мне глупому коффициэнт"
Написано ведь: К - коэффициент, зависящий от схемы выпрямления,
Если вы всю жизнь выпрямители собирали и с двигателями постоянкой возились вы должны эти формулы знать, а такие справочники - это настольная книга электрика, как и ПУЭ.
  • Удивительное с АлиЭкспресс
Удивительные товары с Aliexpress
Валериан
Сообщение Валериан » 12 сен 2010, 15:05
От yura:
Нарисуйте мне схему выпрямления в однофазной сети и в трехфазной где ваш коффициент будет больше ЕДЕНИЦЫ,Книги у меня такой нет
От Андрей Я:
Большое спасибо ! Буду искать и пробовать делать.
Сообщение sergey_sav » 12 сен 2010, 15:24
Вообще то любая схема выпрямителя с фильтром в однофазной сети имеет коэф. больше единицы, а точнее 1,41.
А вот с нагрузкой приходится говорить о пульсациях относительно среднего действующего значения.
Валериан
Сообщение Валериан » 12 сен 2010, 20:44
yura. Я не понял, вы мне что предлагаете здесь на форуме изложить основы электропривода постоянного тока? Я вам сказал каким справочником пользоваться, дал ссылки, дальше работайте, считайте.
И не забывайте, что когда вы меряете переменное напряжение цешкой, то вы меряете действующее значение. А есть еще амплитудное значение напряжения.
Эти коэффициенты и учитывают амплитуду напряжения.
StarikDjin
Сообщение StarikDjin » 13 сен 2010, 18:29
yura писал(а):
Интересно вы еше настаиваете что автор замеряет до диодов 130 после диодов 170 и так оно и должно быть.
Дорогой друг о чём спор возьмите 4 диода (кд 226) спаяете диодный мост подключите к сети 220В и замерте напряжение.
Валериан
Сообщение Валериан » 13 сен 2010, 22:02
И будет 220х0,9=198 В.
А речь идет об трехфазной мостовой схеме.
А этого yura не слушайте, он ничего в электроприводе и силовой электронике не понимает
 Новое »
  • Интересные новости
