"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Панельный дом, проект II-49. Модернизация электросети.
  • Всё для электрика
Гарик
Сообщение Гарик » 12 мар, 2010 13:34
Всем доброго времени суток. В связи с покупкой стиральной машины буду бросать времянку от квартирного щитка (в предбаннике) через отдельный автомат. В принципе всё понятно, как делать, однако при осмотре размеров бедствия (каким образом осуществляется ввод в квартиру и какими проводами) в связи с надвигающимся неизбежным ремонтом (в доме сейчас делают капитальный ремонт с утеплением фасадов) возник вопрос - а можно ли выполнить ввод и хотя бы частично разводку по квартире медью вместо существующего алюминия, не делая штробов, а используя существующие кабель-каналы внутри бетонных плит и перекрытий? Или там всё замуровано наглухо? Алюминий от автоматов входит в такой кабель-канал и ничем не замурован (вроде бы). Заранее спасибо.
Сообщение Похожие темы » 12 мар, 2010 13:34
Модернизация станка
Модернизация котла Пирамида
Модернизация Mercedes-Benz Sprinter грузовой
Расчёты электросети
Что это за приборы на проводах электросети?
makslelik
Re: Панельный дом, проект II-49. Модернизация электросети.
Сообщение makslelik » 12 мар, 2010 13:52
Здесь я не советчик, но есть маленький опыт с панельным домомНадо было поменять кабель от распред. коробки до розетки. Обесточил,пошевелил(туда,обратно)-второй конец шевелится,значит не замурован. Скрутил с новым кабелем и протянул. Примерно так.
Гарик
Сообщение Гарик » 12 мар, 2010 14:08
В общем-то это всё впереди - имею в виду шевеление провода. Просто обратил внимание (методом простукивания -:: ), что в квартире в верхних частях стен имеются какие-то встроенные пустоты. Возможно там что-то наподобие распаечных коробок. Поэтому и подумал, что где-то можно и не штробить :))mega
Сообщение ВИТАЛИЙ ЙЙ » 12 мар, 2010 14:28
такая ? 11 49
Панельный дом, проект II-49. Модернизация электросети. - tb_1628.jpg (9.79 КБ) 3111 просмотров
Сообщение миш » 12 мар, 2010 16:47
в практике замен проводки много и если вы найдете проходные отверстия это будет ураааааа. а вот они заделываются .
Гарик
Сообщение Гарик » 15 мар, 2010 6:53
2 Виталий ЙЙ. Не, II-49 - это брежневские 9-этажки. По сравнению с индустриальными 5-этажками прогресс, но слышимость конечно офигенная (в П-44Т кстати слышимость не лучше), и кухни масюсенькие, меньше 6 м в квадрате. Найду фоту - прилеплю.
2 МИШ Из квартиры в предбанник 2 выхода - один из них назову "слаботочный" - через него протянуты антенна, домофон, телефон и другая дребедень, собственно через него и вывели с сыном вчера проводку к стиралке. Второй выход - электросеть, выходят два двухжильных кабеля, алюминий (подозреваю, что сечением 2 мм в квадрате), и труба, в которую входят эти кабели, не заделана. Но шевелить не пробовал, каюсь :)
Сообщение ВИТАЛИЙ ЙЙ » 15 мар, 2010 7:26
та была к-7 ошибся...коробки (которые вы простучали)-в них еще разберетесь,а провода вмазаны в стену наглухо.
может получиться протянуть провод в потолке-там каналы в плитах-пару раз делал работы в таких домах-менял всё
Панельный дом, проект II-49. Модернизация электросети. - tb_1598.jpg (7.65 КБ) 206 просмотров
Гарик
Сообщение Гарик » 15 мар, 2010 8:03
Ага, понятно... Значит штробов всё-таки не избежать. Спасибо за помощь! :)
Сообщение ВИТАЛИЙ ЙЙ » 15 мар, 2010 8:08
ели уж делать ,то капитально!!!!!
Гарик
Сообщение Гарик » 17 мар, 2010 9:39
:) Сделаем! {!}
 Новое »
