"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Мигающие светодиоды на эл.счётчике
  • Всё для электрика
Семёнов
Сообщение Семёнов » 20 фев, 2010 21:54
Энергосбыт сменил дедовский эл.счётчик (который работал без вопросов) на новый электронный (NIK-2102-02, Киев).
Вопросы появились сразу.
За первые же 10 часов накрутил 40 кВт/ч при работающем эл.конвекторе на 2 кВт/ч, разово бойлер, и лампочки пару часов.
На новом эл.счётчике есть светодиоды:
1. "6400imp/kW.h" - горит почти постоянно. Очень редко мигнёт.
2. "Реверс" - не загорается.
3. "Земля" - загорается где-то каждые 2 секунды. И горит секунд 5.
____________________________________________________________
У соседки на этом же щитке такой же счётчик два года назад поставили: у неё п.1 и п.2 такие же. А "Земля" не загорается".
Уважаемые специалисты, о чём говорит горящий светодиод "Земля" ?
Спасибо.
Сообщение Похожие темы » 20 фев, 2010 21:54
Греется ноль на счетчике...
Показания на счетчике СЭТ4-1
Пропала индикация на счетчике ЦЭ6827М
Цифры на счетчике как считаются на потребление энергии
На счетчике скакнули показания с 25000 до 75000, что делать?
Сообщение Anatoliy » 21 мар, 2010 14:32
Такой вопрос уже не раз всплывает на форумах. Вам там дали ответ на него.
diana7510
Re: мигающие светодиоды на эл.счётчике
Сообщение diana7510 » 18 фев, 2012 14:18
Добрый день! Подскажите пожалуйста должны ли мигать светодиоды А В С на нормально подключенном счетчике НИК 2301 АП1. И что обозначает ихнее мигание.
PavelP-y
Сообщение PavelP-y » 18 фев, 2012 20:49
Светодиоды А В С не должны мигать при нормальном подключении и при нормальном напряжении.
Состояние индикаторов ”А”, ”В”, ”С” Описание ситуации
1 для счетчиков НІК 2301 АП1, НІК 2301 АП2, НІК 2301 АП3, НІК 2301 АК1
1.1 Индикаторы не горят Штатная работа счетчика
1.2 Частое мигание (с перидом 0,5 с) одного из индикаторов ”А”, ”В” или ”С” Напряжение соответствующей фазы на входе счетчика более 1,15 Uном
1.3 Мигание (с перидом 2 с) одного из индикаторов ”А”, ”В” или ”С” Напряжение соответствующей фазы на входе счетчика менее 0,8 Uном
1.4 Индикаторы ”А”, ”В”, ”С” последовательно загораются и гаснут Обратная последовательность фаз на входе счетчика
1.5 Одновременно мигают. Индикаторы ”А”, ”В”, ”С” одновременно загораются и гаснут Обратное направление тока в одной из фаз (реверс)
2 для счетчиков НІК 2301 АТ1
2.1 Индикаторы не горят Штатная работа счетчика
2.2 Частое мигание (с перидом 0,5 с) одного из индикаторов ”А” или ”С” Линейное напряжение Uав или Uсв на входе счетчика более 1,15 Uном
2.3 Мигание (с перидом 2 с) одного из индикаторов ”А”, ”Б” или ”С” Отсуствует напряжение соответствующей фазы на входе счетчика
2.4 Индикаторы ”А”, ”В”, ”С” последовательно загораются и гаснут Обратная последовательность фаз на входе счетчика
2.5 Одновременно мигают. Индикаторы ”А”, ”В”, ”С” одновременно загораются и гаснут Обратное направление тока в одной из фаз (реверс)
 Новое »
