"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Надёжность светодиодных светильников
  • Всё для электрика
Сообщение Mixas » 21 окт, 2019 9:33
Уважаемые коллеги! Предлагаю обсудить тему надёжности светодиодной техники - прожекторы, уличные консольные светильники, светильники ЖКХ - освещение подъездов, дворов, бытовые светодиодные лампы -взамен ламп накаливания. Дальше так продолжаться не может!!!! Полтора года назад купили 500 штук лампочек светодиодных 10 Вт. Осталось меньше 100 шт. Остальные все сгорели! Построили линию освещения из 32 светильников мощностью по 100 Вт. Зиму простояла, летом светло -как-бы и не надо света - Осень пришла Света нет. Стали выяснять причину- оказалось, что все светильники, все 32 штуки сгорели!!! Отправили на завод изготовитель по гарантии. Там ремонтировать не стали, сказали что все светильники вышли из строя по причине грозовых разрядов. Звоню в другой город энергетику по освещению всего города - он сообщает что построили линию освещения из 50 светильников. Через неделю 10 штук сгорели!!! Кто может сказать - что твориться? Есть у кого какие объяснения? У меня есть рабочее предположение о причинах отказов светодиодной осветительной техники и не только светодиодной, а также индукционных светильников. Часть вышедших светильников и ламп отправил на экспертизу в лабораторию - жду заключения. Получу заключение и выложу свою версию причин перегорания светодиодной техники. Интересно отметить, что в лабораторных условиях на заводах по выпуску этих светильников всё замечательно работает и все светильники проходят стендовые испытания!
Сообщение Похожие темы » 21 окт, 2019 9:33
Монтаж светодиодных светильников.
Подключение светодиодных ламп
Мерцание светодиодных ламп
Мерцание светодиодных, димируемых ламп.
Re: Надёжность светодиодных светильников
Сообщение slavapril » 21 окт, 2019 15:35
В свое время ставил очень дорогие (в 2015г - 2000р/шт) светильники Энтрада
Светодиодные светильники «Энтрада» предназначены для общего освещения объектов жилищно-коммунального хозяйства. Светильники выпускаются как в обычной модификации, так и с датчиками движения, освещения и шума для работы в дежурном режиме.Для настройки режимов (степень яркости дежурного режима, чувствительность срабатывания от уровня освещенности, радиус действия и т.д.) прилагается пульт к ним. Работают до сих пор.
Еще раньше ставил Символ-Д-107-Д (в 2014г стоил 800р)
Без пульта, все настройки заводские, но тоже есть дежурный режим. Работают до сих пор. А вот обычные светодиодные да - перегорают. Не так часто как обычные, но тоже со своей статистической периодичностью. Матрицы нормальные, драйвера накрываются.
Сообщение миш » 23 окт, 2019 13:36
Mixas я писал Светодиодный светильник ссп 159, проблема сети или брак светильника.
Правда не оставил конечный результат. Он был таким, брак светильников.
Складывается устойчивое мнение, что для дома светодиодные лампы работают, а в коммерческом исполнении много брака. Покупали прожектора 10шт из них 2 сгорели на второй день.
Сообщение slavapril » 23 окт, 2019 15:48
миш писал(а):
Источник цитаты в коммерческом исполнении много брака
Производитель борется за товарооборот
Сообщение миш » 23 окт, 2019 16:21
Слава и я так думаю.
Сообщение Mixas » 24 окт, 2019 4:37
Интересная ситуация. А можно поинтересоваться лампы и прожектора примерно на каком расстоянии по кабельной разводке находятся от подстанции питания? Имеются ли рядом потребители электроэнергии с потреблением большой мощности?
Сообщение миш » 24 окт, 2019 6:58
Mixas, прожектора покупались для дополнительного света, при монтаже в подвальном помещение.
Они использовались как переносное оборудование. Причём в них выгорал именно светодиод. Я сейчас не знаю сколько осталось в живых. Примеров много и все они относятся к промышленному использованию. Чердак многоквартирного дома, установлено 48 штук, сняли 5 шт- брак. Сняли через месяц этот брак, а когда именно они вышли из строя не знаю.
Сообщение Mixas » 25 окт, 2019 4:42
Всем привет! Пришёл ответ по отказам ламп и другой светодиодной осветительной техники. Причина отказов целый букет! 1. плохой теплоотвод от светодиода (Отсутствует теплопроводящая паста). 2.Ненормативный завышенный ток на 20% через светодиод в результате чего происходит деградация P-N перехода (Ток идёт а квант света не образуется)
3. Выход из строя источника питания (И светодиодов тоже) по причине отсутствия или слабой защищённости от высоковольтных импульсов распространяемых в сетях 0,4 кв. Об этом поподробнее.
По закону Фрадея-Максвела о самоиндукции в контуре электрической цепи состоящей из трансформатора и электрической нагрузки возникают импульсы самоиндукции и которые по правилу Ленца имеют знак "+" или "-" в зависимости включается или отключается нагрузка. Когда нагрузка включается, то знак "-" , а вот при отключении нагрузки и чем быстрее её отключаешь тем импульсы по амплитуде больше и по длительности короче. Амплитуда достигает 3-5 кВ и длительностью от 1 мсек до 100 мсек. Эти импульсы называются коммутационными. Они выдаются непосредственно трансформатором на подстанции 6/0,4 кВ и распространяются по всем сетям 0,4 кВ с затуханием. Передний фронт импульса очень крутой, поскольку крутизна его определяется наличием высших гармоник 2,3и 4, Те частоты порядка 0,1-0,25 мГц. Все электрические нагрузки, находящиеся рядом с подстанцией в радиусе 300-400 метров попадают в самые жёсткое воздействие от коммутационных переключений (Не важно где и как в каком месте произошло отключение нагрузки) Дальше от подстанции гармонические составляющие быстро затухают, остаётся первая гармоника с частотой 50-60 кГц, импульс "Расползается" и его амплитуда уменьшается.
Сетевыми компаниями на сетях 0,4 кВ устанавливается варисторная защита для гашения таких импульсов с целью защиты сетей от пробоя изоляции и недопущения образования плазменных возгораний на изоляторах, межфазных замыканий на проводах и кабелях. Т.Е применение низкочастотных полупроводниковых ограничителей напряжения защищают СЕТИ. А вот новые технологичные светильники по программе энергосбережения светодиодные лампы, прожекторы, уличные светильники с полупроводниковыми приборами в источниках питания (ПРА) в том числе и бытовые светодиодные лампы оказались без защиты! К примеру распространённый ограничитель импульсных напряжений ОПС 1-D включается в работу после 25 мсек ограничивая низкочастотную спектральную часть коммутационного импульса и пропускает крутой высокочастотный фронт амплитудой 3-4 кВ длительностью 1-10 мсек. что достаточно для пробоя светодиодов и источников питания. В завершении всего фото что делают коммутационные импульсы.
Сообщение миш » 25 окт, 2019 5:33
Mixas, как всегда возникает вопрос, как быть и что делать?
Сообщение slavapril » 27 окт, 2019 17:34
Ну, если эта теория верна, то попробовать хотя бы на одну из линий с лампами поставить RC-фильтр (сгородить)
 Новое »
