"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Кварцевые обогреватели ТЕПЛЭКО - отзывы
  • Всё для электрика
Сообщение elhouse » 26 янв, 2018 6:53
Выкладываем здесь все отзывы о данном разрекламированном бренде.
Вот несколько отзывов из интернета:
Николай. Не обогреватель это а плита из мраморной крошки которая трескается сразу после включения. Гарантии нет на трещины. Читайте паспорт Теплэко на последней странице написали-трещины не влияют на работу и не являются гарантийным случаем. Ерунда полная. Пожароопасная к тому же. Теплэко оказывается выпускает ИП Котенков из под Кемерово (Теплэко торговый знак) Кемерово дыра а Кемеровская область - Дыра в дыре.
Руслан. Вот правда про Теплэко. Теплэко морочит всем голову. У Теплэко нет Патента на Кварцевый обогреватель. У Теплэко Патент на электронагреватель (Патент на Кварцевый обогреватель только у ТеплопитБел из Беларусии). У Теплэко нет гарантии (товар целый год продается на Акции, должны заключить договор за дополнительную плату на подключение)-читайте паспорт перед покупкой, не получите деньги в случае возврата - не зависимо от причин. Теплэко продает только по Интернету (Али-Баба почтой) - что пришло то и получи, возврат не предусмотрен (товар круглый год Акционный). Теплэко в 99% с трещинами или трескается в течение 50 минут. Поэтому в паспорте и прописано что можно эксплуатировать с трещинами. Вас разводят как в детском саду. Где это видано в мире, что бы электроприбор можно было эксплуатировать с трещинами-ТЕПЛЭКО. Теплэко продается с кабелем 50 см., без вилки (прикручивай сам), без кронштейнов (доплати отдельно), без отражателя (доплати отдельно). Более того, Теплэко потребляет не 0.4кВт/час а все 0.57 квт/час. Сделайте замер тестером на сопротивление. Получается Теплэко самый дорогой и самый некачественный обогреватель. Развод. Весь интернет забит положительными отзывами, которые они сами себе и пишут, и в тоже время пишут негативные отзывы на своих конкурентов-ТеплопитБел-РБ, Теплоплит-РФ, Теплопит-РФ. Не верьте. Наберите на Ютубе Теплэко и посмотрите реальное положение дел. Как вообще ИП Котенков который выпускает эти электронагреватели в Кемерово сумел получить Сертификат на прибор, который можно эксплуатировать с трещинами? Требуйте копию паспорта перед покупкой и заказом что бы ознакомиться с условиями и эксплуатацией, прочитав, Вы сами убедитесь в качестве Теплэко.
Сообщение Похожие темы » 26 янв, 2018 6:53
Обогреватели жгут!
Инфракрасные обогреватели
Инверторы Энергия ПН отзывы
Отзывы о стабилизаторах фирмы ИЭК
Стабилизаторы напряжения Энерготех - отзывы
Re: Кварцевые обогреватели ТЕПЛЭКО - отзывы
Сообщение elhouse » 26 янв, 2018 7:01
Тут все пишут какие славные обогреватели эти ТеплЭко, чушь это все одна реклама.
Купил себе в магазине 8шт поставил 4шт с датчиками 1 датчик не работает. На двух обогревателях после двух дней работы появились трещины пополам. Звоню дилерам в Москву там брал сто верст до них. Ответили это не гарантийный случай у нас указано в паспорте что возможны трещины в 350мм.!!! при размерах обогревателя 600*350*25ммм. то есть пошли на... х. А где напрашивается эстетический вид самого обогревателя???? Потом почитал отзывы о них и ... одна реклама что они такие хорошие и пушистые. В общем НЕГАТИВ об этой компании. не советую приобретать у них что либо.
Не выполняет заявленные функции, компания предоставляет неверную инфо по доставке и разводит на деньги.
Не поддавайтесь на провокации с хвалебными отзывами - все они подделка!
Я купила этот "замечательный" обогреватель для обогрева маленькой дачной террасы. Тепло от обогревателя распространяется сантиметров на десять от него и все. Сколько он должен работать, чтобы обогреть помещение 6 кв. м при температуре за окном не выше +15? Думаю, неделю без перерыва как минимум. В самой компании после того, как я начала жаловаться сказали, что его ставят под стол ноги греть. Т. е все будут мерзнуть, а ноги будут в тепле? Что за бред? Заметьте, что на сайте не указано предельная температура нагрева воздуха в помещении, указано только температура нагрева поверхности.
Достав его из коробки, по краю обогревателя уже облупилась краска. просто замечательно.
Хочу поделить своим впечатлением об кварцевом обогревателе и самой фирме ТЕПЛЭКО. А впечатление весьма неоднозначное. Обогреватель нам нужен был в детскую для подстраховки на холодное время года, т. к. не всегда температура в квартире была комфортной. Хотелось, чтоб обогреватель был безопасным, более-менее экономичным, не был громоздким и эффективно нагревал воздух в комнате. Масленные обогреватели отпали сразу, так как потребляют оч много электроэнергии и не особо эффективно нагревают воздух (пользовались-знаем). Тепловентилятор (калорифер) выжигает и сильно пересушивает воздух. Инфракрасные останавливали из-за своей цены... И тут мы наткнулись на информацию о кварцевых обогревателях ТЕПЛЭКО. Ознакомившись с информацией на сайте компании мы решили сделать заказ, тем более в тот момент на этот обогреватель была цена по акции всего 2400₽ очень ограниченное количество времени. Потом мы уже выяснили, что эта цена (2400₽) у них постоянная 365 дней в году, а мнимой акцией они заманивают покупателей) Неплохой маркетинговый ход. Оплатили заказ сразу и стали ждать свои обогреватели. А ждать пришлось долго! На сайте указано, что доставка от 1 до 6 дней. Мы ждали 22 дня!! Несколько раз звонили операторам, чтоб узнать хоть что-то о нашем товаре. Операторы не самым вежливым образом нехотя отвечают, что заказав много и придётся подождать, в течении 15 дней они отправят. На вопрос почему так долго, ведь на сайте написано о 6 днях максимум отвечают, чтоб внимательно читали договор офетры, в котором указанно, что они имеют право отправлять товар в течении 15 рабочих (подчёркиваю РАБОЧИХ) дней.
К транспортной компании претензий нет, оператор прозвонила и сообщила о прибытии товара, стоимости доставки и о том где и когда мы можем забрать товар.
Теперь о самом обогревателе поподробнее. Он достаточно тяжёлый, это связанно с его конструкцией. Внешний вид на троечку. Лицевая сторона (на первом фото) ещё более-менее выглядит, а тыльная сторона (второе фото) уж совсем не привлекательна.
Сообщение elhouse » 26 янв, 2018 7:12
Пользуюсь на даче обогревателями NOBO. Установлено 10 штук по 1 кВт. 10 лет эксплуатации и горя не знаю. Качество обалденное, но дорогие.
А вот рекламу ТеплЭко распространяемую спамерами на моих форумах - удаляю постоянно. Вы когда нибудь видели спам NOBO? Вот и я про то.
Сообщение ВИТАЛИЙ ЙЙ » 26 янв, 2018 7:21
Дааа! что то отзывы совсем не то что хотел услышать ) Если есть трещины, то по логике будет иметь деформацию кабель - так как он залит в монолите (мы же не знаем какой там нагревающий кабель заложен)
Магазин есть - я узнал ! вот думаю купить для пробы и убедиться! даже стало интересно! цена радиатора 2400 р Так что посмотрим!
Пока искал этот бренд, на форуме выскочил другой: НИКАТЕН - но его пока не рассматриваем.
Если кто что знает по своему опыту - пишите!
Отправлено спустя 13 минут 37 секунд:
Я обязательно куплю его - проверю - так как стало интересно! Очень много видео с положительными результатами - если что - то будет чем опровергнуть
Тут пришла идея - можно же сделать самому такие и будет дешевле - купить кабель от теплого пола - порезать его - залить - и норм! (регулятор так же самодельный) кварцевый песок - так же можно сделать - что бы не закупать :))biggrin
Сообщение elhouse » 26 янв, 2018 7:39
ВИТАЛИЙ ЙЙ писал(а):
Источник цитаты Тут пришла идея - можно же сделать самому такие и будет дешевле - купить кабель от теплого пола - порезать его - залить - и норм! (регулятор так же самодельный) кварцевый песок - так же можно сделать - что бы не закупать
Так они так и делают. Это не обогреватель, а кусок тёплого пола.
Налаживай производство...
Назовём "ТеплоНано". Дураков в инете больше чем ты думаешь. Сам убедился за 25 лет телефонного общения с заказчиками.
Вот так выглядит обогреватель ТЕПЛЭКО после нескольких включений.
Снято пользователем с мобилы:
Отзыв: Страшный для использования обогреватель. Производителем гарантированы трещины и поражение электрическим током. Прописано в Паспорте Теплэко.
Недостатком Теплэко является более низкое качество. Покрытие очень часто трескается, что сказывается как на внешнем виде, так и на работе. Но трещины до 35 см в техпаспорте обозначены естественными и не проходят по гарантии. Очень странно, что гарантийным случаем не является разрушение панели, которое может со временем продолжиться. Возможно, это попытка скрыть прорехи в технологии, которые не позволяют достичь высокого качества продукции.
Если говорить о качестве, то тут у Тепэко тоже все плохо. По отзывам покупателей, крошка из мрамора быстро трескается и уродует панель. На деле, данная техника не является даже кварцевым обогревателем, скорее это не слишком удачная попытка создать альтернативу.
Я бы такое г*вно никогда себе не купил.
Сообщение ВИТАЛИЙ ЙЙ » 26 янв, 2018 8:15
Технологи М-даки - надо армировать - тогда не будет трещин и пластификатор класть!
Сообщение elhouse » 26 янв, 2018 8:17
Источник цитаты надо армировать - тогда не будет трещин и пластификатор класть!
Тогда цена увеличится. А народу ведь нужна "халява".
Источник цитаты Я обязательно куплю его - проверю
Уже всё проверили до тебя...
Сообщение ВИТАЛИЙ ЙЙ » 26 янв, 2018 8:29
Согласен! -- это такой же теплый пол - только на стене -- вот если поставить регулируемые вентиляторы с низу радиатора - то эффект был бы лучше
Сообщение elhouse » 26 янв, 2018 9:04
Купи Норвежские обогреватели NOBO и забудь о проблемах навсегда. Тем более ими можно управлять (встроен контроллер) с сигнализации, мобилы или от умного дома.
У них 4 провода подключения - фаза, ноль, земля и управляющий.
Angelkaa
Сообщение Angelkaa » 23 авг, 2019 14:01
Обогреватели Теплэко активно рекламируют и хвалят, на самом деле все это неправда. Это очень слабые приборы, которые долго нагреваются, слабо греют и плохо прогревают помещение. При сильных морозах они будут совсем бесполезны. Но это еще не все! У них не прикреплена вилка и ее нужно сначала заземлять. Вызвала для этого мастера, который сказал, что при работе прибора по кафелю босиком по дому лучше не ходить, так как при малейшей лужице может ударить током. Также от его работы стоит несусветная вонь, искрит кнопка переключателя и выбивает УЗО. Кроме этого, я получила обогреватель с корпусом, который весь в царапинах и не совсем целой подставкой. От прикосновения к нему бьет током. Деньги производители возвращать не хотят, хотя должны сделать это без вопросов. Наталья, Россия
Начитавшись разных отзывов об обогревателях Теплэко, мы решись на их покупку. Рассчитали, что для обогрева нашего дома понадобится двенадцать штук таких приборов. Заказывали на сайте производителя, и через три недели доставка была произведена. Трещин, сколов и других дефектов обнаружено не было, что нас порадовало. Дополнительно покупали терморегуляторы, через которые и подключали в каждую комнату по два устройства. Работали они больше суток, но ожидаемого тепла мы так и не дождались. Температура в доме выше десяти градусов не поднимается. Обогрев помещений идет постоянный, регулятор приборы не отключает, поскольку нужная температура не достигается. В результате и экономии электроэнергии никакой нет. Приборы очень маленькие по размеру и я считаю, что цена на них завышена. Получается, что мы выбросили деньги на ветер. Анна, Россия, Железноводская
 Интересное »
