"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Надёжность светодиодных светильников
Тех. поддержка
Тех. поддержка
Инженер
Инженер
Re: Надёжность светодиодных светильников
Сообщение Mixas » 28 окт, 2019 6:48
Правильно Вячеслав! Необходимо на свои сети собственнику поставить фильтры- заслон от проникновения коммутационных импульсов. Ранее когда горели лампочки Ильича импульсы в сетях ни кого не интересовали и со времён принятия программы ГОЭРЛО - ИНДУСТРИАЛИЗАЦИИ + ЭЛЕКТРИФИКАЦИЯ ничего в схемах электроснабжения городов и предприятий не изменилось. И вот настал век высоких технологий. Поступило распоряжение лампочки накаливания запретить а светодиоды ставить! А о сетях кто-нибудь ПОДУМАЛ? А потому всё ужасно плохо Все ГОСТы на сети и на качество электроэнергии безнадёжно устарели. Все подстанции надо оснащать другими ячейками, предотвращающие генерацию импульсов и гармоник отличных от 50 Гц.
А пока необходимо самостоятельно изготавливать эти самые фильтры по следующим схемам: Фильтр Четырёхполюсник. !,2 вход. 3,4 выход. Дроссель намотан на электроизоляционном феррите 2000НН (Можно 600НН, 400НН). Можно взять феррит от отклоняющей системы стеклянного кинескопа. Количество витков 10-15, медным проводом 6 квадрат. Конденсаторы желательно безиндуктивные фторопластовые, тонкоплёночные, можно бумажные но смещением обкладок на напряжение не менее 1000В. ёмкостью 0,2-1 мкФ.
Сообщение Похожие темы » 28 окт, 2019 6:48
Монтаж светодиодных светильников.
Подключение светодиодных ламп
Мерцание светодиодных ламп
Мерцание светодиодных, димируемых ламп.
Тех. поддержка
Тех. поддержка
Инженер
Инженер
Сообщение Mixas » 28 окт, 2019 7:01
Конденсаторы. Фильтры на частоту среза 50 кГЦ. Есть фильтры промышленные, но с частотой среза со 100 кГц. Так к примеру фильтр (Европа) на 30 Ампер начинает давить импульсы выше 100 кГц и больше предназначен для подавления радиопомех.
Тех. поддержка
Тех. поддержка
Инженер
Инженер
Сообщение Mixas » 06 ноя, 2019 7:39
Всем привет! В продолжении темы. Возникла проблема и не только у меня а у всех,кто занимается освещением города. Новые линии освещения выполняются светодиодными светильниками. А о сетях ни кто не подумал. Как были они с коммутационными импульсами так и остались. Амплитуда импульсов 3-5 кВ, длительность 1-100 мсек. Передний фронт импульса определяется 2,3,4,5 гармониками и имеют частоту от 50 до 200 кГц. Ограничители напряжения например ОПС-1D на варисторах низкочастотные и включаются в работу через 25 мсек. (Паспортный данные) Т.Е передний фронт проходит и выбивает вторичный источник питания и светодиоды.
Необходимо устанавливать Высокочастотные варисторы с быстродействием 20-100 наносекунд и сетевые фильтры с токами 30, 60, 90 ампер в трёхфазном исполнении.
Сетевой вильтр для питания светодиодных линий освещения должен быть законченным блоком через который подключается шкаф управления освещением.
Фильтр должен содержать в себе дроссель на электроизоляционном ферите 2000НН и безиндуктивные конденсаторы 0,5- 1 мкФ.
Для квартирного сетевого фильтра необходимо его исполнение в однофазном исполнении на токи 30-40 Ампер (Светодиодные лампочки то перегорают)
Задачи определены! Кто возьмётся за реализацию? На рынке восстребованность по защите светодиодных светильников.
Сообщение slavapril » 08 ноя, 2019 10:54
Mixas писал(а):
Источник цитаты Амплитуда импульсов 3-5 кВ, длительность 1-100 мсек. Передний фронт импульса определяется 2,3,4,5 гармониками и имеют частоту от 50 до 200 кГц.
Может, я уже забыл тему - данные-то откуда такие? Теория или замеры?
Отправлено спустя 32 секунды:
Mixas писал(а):
Источник цитаты Фильтр должен содержать в себе дроссель на электроизоляционном ферите 2000НН и безиндуктивные конденсаторы 0,5- 1 мкФ
А эти данные откуда?
Тех. поддержка
Тех. поддержка
Инженер
Инженер
Сообщение Mixas » 12 ноя, 2019 3:41
Хорошие Вопросы? Я когда стал разбираться в этой проблеме и был ещё больше удивлён! Оказывается об импульсах по сетям 0,4 кВ Все знают! Главные специалисты в сетевых компаниях, в энергетических университетах (Томский политехнический университет) и конечно подробности в инете - грозовые импульсы и коммутационные импульсы и их отличия, крутизна фронтов, длительности и ТД. Наверное не одна диссертация написана. А далее всё просто- есть теория " Радиотехнические цепи и сигналы" 3-курс Новосибирского университета электроники (НЭТи) или Томский ТУСУР.
фильтры типа "М" и типа "Т" На этих частотах пермалои не работают. Надо брать ферриты. Ферриты тоже разные. Есть высокочастотные и низкочастотные. Выбор за разработчиком. Конденсаторы-выбор огромный, но надо ориентироваться в их частотных характеристиках. Электролитические на переменном токе не работают. Большое знамение имеет из чего сделан конденсатор и как, а отсюда его частотные свойства.
 Новое »
