"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Заземление УЗП-220
Консультации и обсуждение вопросов устройства и эксплуатации заземлителей, контуров, систем уравнивания потенциалов и молниезащиты. (Только для членов клуба и VIP-пользователей). Как вступить в "Клуб электриков" и стать VIP-пользователем?
  • Всё для электрика
Нублес
Заземление УЗП-220
Сообщение Нублес » 02 авг, 2019 8:35
Доброго часа. Уважаемые форумчане, столкнулся с проблемой и не могу понять.
Подключаем прожекторы на объекте, которые идут через пускатели и втягивающее РЕЛЕ. Присутствует фотоэлемент при сработке которого - втягивает РЕЛЕ.
Так же от РЕЛЕ идёт к прибору "С2000-СП1" через Устройство защиты оборудования "УЗП-220".
При сработке фотоэлемента, втягивающее РЕЛЕ выбивает автоматы. Когда откидываем кабель заземления от Устройство защиты оборудования "УЗП-220" - всё прекрасно работает.
doc00409420190802111943.pdf
(1.19 МБ) 4 скачивания
Заземление УЗП-220
Сообщение Похожие темы » 02 авг, 2019 8:35
Заземление v 3.1
Заземление и УЗО
Заземление РЩ
Заземление ВЛ-10, ВЛ-0,4 кВ
Заземление
Re: Заземление УЗП-220
Сообщение slavapril » 02 авг, 2019 15:43
Ну, отсюда не видно как там подключено...PE-проводник заведен на УЗП-220 и заземлен?
Нублес
Сообщение Нублес » 05 авг, 2019 5:51
Да. Всё верно. На шину.
 Интересное »
