"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Как восстановить аккумулятор шуруповерта?
  • Всё для электрика
Mius_FRONT
Re: Как восстановить аккумулятор шуруповерта?
Сообщение Mius_FRONT » 24 июн, 2017 13:07
Здравствуй! Подскажите если не трудно. По поводу восстановления аккумулятора шуруповерта. Есть батарея Интерскол 18в рабочая. И есть не рабочая "клаус" )
В общем когда перепаивал коротнул рабочую плату. батарейки живые. (они были заряжены и я их напрямую без платы, как у Вас на картинках показано подсоединил правда были Ni-Cd а поставил Li ion) Сейчас работает, НО как заряжать, не могу понять не будет ли в этом случае перегреваться батарея? (без платы) В общем если откликнитесь подробнее расскажу.
Сообщение Похожие темы » 24 июн, 2017 13:07
Как восстановить автомобильный аккумулятор
Возможность переделки аккум. шуруповерта на AC
Ремонт шуруповёрта интерскол модель ДА-12ЭР-01 нужен совет
Вопрос про аккумулятор
Аккумулятор для генератора
Сообщение elhouse » 24 июн, 2017 15:09
Mius_FRONT писал(а):
Источник цитаты не будет ли в этом случае перегреваться батарея? (без платы)
Именно эта плата и отвечает за ток заряда.
Алиэкспресс по Русски
Slavik85G
Сообщение Slavik85G » 18 дек, 2017 21:20
Надо попробовать с батареями помудрить - лежат две мертвых от Макиты старого. Его с уже использую только с аккумулятором авто или с ИБП (есть такой) Неудобно, что проводной по сути стал. Может и получиться еще элементов рабочих с двух батарей выбрать)
Олег37
Сообщение Олег37 » 05 дек, 2018 17:24
Дохнут и литиевые.
Два в комплекте у шуруповерта АЕG, один перестал заряжаться.
Подлежит реанимации такой пациент? Новый около 3 т.р. Имеет смысл ремонтировать? Что смотреть ? Аккумов раздутых нет. :-)
Volandf
Сообщение Volandf » 05 дек, 2018 17:44
Поменять аккумы, они не обязательно должны быть раздутые, просто свой ресурс отработали и деградировали. Аккумы соединяются лентой на контактной сварке, желательно сделать также, но можно и на пайке (аккуратно и сильно нагретым паяльником).
Олег37
Сообщение Олег37 » 05 дек, 2018 17:52
Volandf, спасибо за науку!, попробовать стоит, есть 18650-е заведомо исправные .
Сообщение sergey_sav » 06 дек, 2018 13:19
Олег37 писал(а):
Источник цитаты попробовать стоит, есть 18650-е заведомо исправные
Менять лучше все разом, чтобы контроллер не дурковал... а снятые аккумы можно применить где-то в прикладных целях...
Сообщение elhouse » 13 дек, 2018 7:38
Калямба писал(а):
Источник цитаты Стоит примерно 600р, +пересылка
В Леруа продаётся шуруповёрт за 650 руб. Я себе на днях купил, как резерв.
Приятель таким отработал весь летний сезон этого года - остался доволен.
ML-CD22-120-N-1
Китай.
Олег37
Сообщение Олег37 » 06 апр, 2019 17:21
Один из шести аккумов был закорочен. Заменил его - теперь все ок.
Сообщение elhouse » 21 ноя, 2019 10:38
Аккумулятор AABB-NEW 2.0AH 12V для шуруповёртов MAKITA 1220 1222 193981-6 6227D 6313D 6317D 6217DWDE 6217DWDLE 6223D 6223DE 6223DW по низкой цене на AliExpress - http://ali.pub/43zt4a
 Новое »
