"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Моргают светодиодные светильники
  • Всё для электрика
grigorymagnus
Сообщение grigorymagnus » 02 сен, 2019 19:39
Здравствуйте. Не знаю в тот ли раздел пишу. Такой вопрос назрел. Имеются светодиодные потолочные панели. Подключены попарно, на двухклавишный выключатель. Появилась проблема. При одновременном включении, начинают моргать по одному светильнику из каждой пары. Если включать либо одну пару либо другую то все нормально. Выключатель без светодиода. Раньше, насколько знаю, проблем не было. В чем может быть проблема?
Сообщение Похожие темы » 02 сен, 2019 19:39
Светодиодные светильники
Светодиодные светильники на кухню
Светодиодные лампы мигают
Энергосберегающие светодиодные лампы
Светодиодные прожекторы SUNTEK
Перемещено из Своими руками в Электроустановочные изделия, дата 03 сен, 2019 2:07, перенёс elhouse.
Re: Моргают светодиодные светильники
Сообщение elhouse » 03 сен, 2019 2:10
Воспользуйтесь поиском. Подобных тем воз и маленькая тележка.
Делайте это всегда прежде чем создавать тему "дубль".
Ответ тут - search.php?keywords=%D0%BC%D0%B8%D0%B3%D0%B0%D1%8E%D1%82+%D1%81%D0%B2%D0%B5%D1%82%D0%BE%D0%B4%D0%B8%D0%BE%D0%B4%D0%BD%D1%8B%D0%B5
grigorymagnus
Сообщение grigorymagnus » 03 сен, 2019 10:00
В тех постах я так и не нашел ответ на свой вопрос. Почему светильники начинают мигать когда одновременно включаешь обе клавиши выключателя. Причем по одному из пары, и всегда одни и те же. И что с этим делать?
Сообщение elhouse » 03 сен, 2019 10:55
Потому что напряжение падает при включении нескольких светильников.
Подключите светильники от нескольких драйверов.
Вы всё нагрузили на один!!! Один драйвер не тянет.
grigorymagnus
Сообщение grigorymagnus » 03 сен, 2019 19:28
Так в каждом светильнике же свой драйвер стоит. В общем поменяли один светильник и проблема пропала...
 Интересное »
