"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=8e3,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div",'\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041c\u044b \u043d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0412\u0430\u043c, \u0447\u0442\u043e \u0412\u044b \u0431\u043b\u043e\u043a\u0438\u0440\u0443\u0435\u0442\u0435 \u043f\u043e\u043a\u0430\u0437 \u0440\u0435\u043a\u043b\u0430\u043c\u044b \u043d\u0430 \u043d\u0430\u0448\u0435\u043c \u0441\u0430\u0439\u0442\u0435. \u041d\u0430\u0448 \u0440\u0435\u0441\u0443\u0440\u0441 \u0441\u0443\u0449\u0435\u0441\u0442\u0432\u0443\u0435\u0442 \u0438 \u0440\u0430\u0437\u0432\u0438\u0432\u0430\u0435\u0442\u0441\u044f \u0437\u0430 \u0441\u0447\u0435\u0442 \u0440\u0435\u043a\u043b\u0430\u043c\u044b.
Соседи сверху воруют электричество
VardDen
Сообщение VardDen » 20 май, 2019 21:12
Здравствуйте уважаемые форумчане!
Есть вопрос по следующей ситуации. Многоэтажный панельный дом серии И-155. Счетчик трехфазный. Уже много лет идет конфликт с соседями сверху. Вопрос технический: если они каким-то образом добрались до моих верхних проводов в квартире, которые находятся за гипсокартонной конструкцией:
1) Могут ли они использовать только свою фазу и мой ноль для того, чтобы мой счетчик учитывал эту электроэнергию, и я ее оплачивал?
При том что на этом же нуле есть моя фаза, которая появляется, когда я включаю у себя свет.
2) Если ответ на 1 вопрос положителен, то как с помощью мультиметра либо другим способом (кроме замеров показаний автомата) проверить течет ли ток по моему нулю при их включенной фазе и моей отключенной фазе?
3) Если они используют мой ноль и мою фазу, то как им все сжечь? Отключить у себя вводный фазовый автомат, все вынуть из розеток, отсоединить нулевую шину и предположительно на самом кратчайшем расстоянии до их врезки в мои провода дать на ноль одну фазу с щитка и соответственно на фазный провод другую фазу? Либо подать одну и туже фазу на оба провода?
Все время перегарают лампочки, когда меня и брата нет дома вырубается свет (вижу по перезагрузке роутера и по духовому шкафу - идет сброс времени), в это время у соседей на моем этаже свет не отключается.
Прошу не иронизировать по данному вопросу и отнестись серьезно, т.к. могу рассказать очень много интересного, от виброколонок, GPS треккеров в днище машины до микроволновых датчиков движения, которые реагируют на движение через бетонное перекрытие т.к. работают на частотах от 5 до 20 ГГц коим бетон в 25 см. не является преградой при соответствующей мощности.
Сообщение Похожие темы » 20 май, 2019 21:12
Выбивает мой общий УЗО из-за соседа сверху...
Электричество из катушки
Столб электричество!
Как сэкономить электричество.
Однопроводное электричество !?!?
Re: Соседи сверху воруют электричество
Сообщение slavapril » 21 май, 2019 16:33
1) воровать надо фазу, а не ноль. Ноль у всех один и общий.Если фаза будет у них ваша, то да - платить будете вы. Мне вот только интересно - вы имеете ввиду, что подкрались к вам за стеной? Я не могу предположить, что за потолком.
2) в разрыв подозреваемой фазы включить амперметр и светильник, который питается с этой фазы или в розетку этой линии что-то (утюг, лампа). Если ток этой фазы будет больше, чем ток вашего устройства, значит, еще что-то потребляется. Но всем этим заморачиваться должен человек, который в этом понимает.
3) советовать ничего не буду - дело подсудное. Это все равно, что внутри вашей личной дачи натянуть проволоку с напряжением от воров.Погибший вор, конечно, будет доказательством его несанкционированного перелазания через ваш забор с целью воровства, но мотать срок вам за это все равно придется.
VardDen
Сообщение VardDen » 21 май, 2019 22:39
Нет. Я имею ввиду соседей сверху. Несколько раз приходил домой и было срабатывание узо, т.е. в момент прихода электиричества в квартире не было. Технически, думаю любым китайским прибором можно измерить приблизительное местоположение проводов в моем потолке. Далее 25 см. бетонное перекрытие толстое сверло. Досверлиться до моих проводов, при разрыве срабатывает узо и сколько то минут чтобы попытаться например сделать спайку и отвести к себе фазу. Это предположение. Просто конфликт серьезный и объяснить почему все время отключается плита и презагружается роутер когда меня нет дома не могу. Там люди реально с поехавшей крышей - установили видеонаблюдение за квартирой, переключают мне телевизор через потолок, я сам попробовал пультом своим от самсунга через стену с балкона - сработало, ведь моя модель телевизора работает на радиочастоте, у нее только вкл/выкл на ИК.
У меня была ситуация когда соседи снизу на другой квартире перебили мне кабель в моем полу. Т.е. они сверлили себе потолок и перебили мне кабель залитый в углу в пол, потом в течение некоторого короткого времени сделали скрутку видимо - в квартиру к себе так и не пустили. С тех пор я уже новый кабель кинул, поскольку на старом скрученном ими все время прыгало напряжение.
А по поводу того чтобы им все спалить - не пойму что тут противозаконного если они ко мне подключились. Ведь если они только взяли от меня фазу, то тут только можно либо повышенное напряжение подать либо импульсную помеху мощную послать, ну и перегорит у них например телевизор. Какая это статья? Ведь надо еще будет доказать что я сделал это специально и как они объяснят что они соединены к моей фазе? - никак думаю.
 Удивительное »
  • Скидки дня
Сейчас этот форум просматривают: Alexa [Bot] и 1 гость
